Question about Dishwashers
Bosch dishwasher shx46a06uc
Diagnostic procedures
4 Suggested Answers
howapp
SOURCE: My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
Posted on May 21, 2009
  • 457 Answers
SOURCE: our 3yr old Bosch dishwasher model SHX46A06UC/46
the control module has be changed. you can go to thermador .com you can order it from them
Posted on Apr 10, 2010
  • 110 Answers
SOURCE: bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Posted on Apr 18, 2012
The water supply line to my Bosch dishwasher (model # shx46a06uc/21) froze. We didn't realize this and tried to run the dishwasher. Now the line is unfrozen, but the dishwasher still won&#
Check for water supply to the valve. Check for 120vac at the valve during fill cycle. If you have both, the water inlet valve is bad, part number 00425458.
Jan 12, 2015 | Bosch Dishwashers
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
BOSCH SHX46A06UC DISHWASHER WATER IS COLD, DISHES ARE FILTHY
We had this a while back - it was something to do with a blocked filter right inside, which meant the hot wasn't coming on. The repair man had to put in a new filter, which had been blocked possibly cos we had been doing quick washes with environmentally friendly detergent, and that solved the problem.
Jan 21, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher shx46a06uc-30
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
My Bosch dishwasher (shu30) sticks in the rinse
Not sure why you would want to remove the panel? When this problem occurs First try putting in diagnostic mode and going thru the cycles. Anyway the tech sheet will be located behind the panel this will walk you thru putting in diagnostic mode.
There is a series of 4 screws that hold the top portion on. These are located on the inside of the door and require a torx bit to remove. Remove the screws and then lift up and out on the cover to remove. There is not a lot of wire there so I usuall remove the lower panel also,same procedure just remove the screws and slide down slightly to remove this panel. You will have to plastic pcs that slip over the hinges at the bottom and these may fall off when removing the panel. To reassemble put lower panel on first and leave the top two screws out until the control portion is installed then put in the rest of the screws.
Mar 24, 2010 | Bosch 23 in. SHU303 Built-in Dishwasher
May 10, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch dishwasher won't shut off. The timer says "1" forever and when you open it there is about an inch of SOAPY water still there.If you press start it goes to "13" and again counts down to "1" and...
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Feb 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHV 6800 dishwasher, 2HR error
Bosch dishwasher all cycles start at 2H and get hungup on 1 min.
Jul 02, 2008 | Bosch SHU9950 Dishwasher
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
Owen Barnes
