Devireg 550 problems
Keeps flashing
My 2011 nissan STX 550 cruise control is not working, it keeps flashing but wont work. Have had it into dealers a number of times. It comes out working but within stop/starts it stops working again
If you're finding it difficult to service/repair your
car i know
a website that has every info on all vehicles and vehicle problems, with their solution In detail.. it's www.reliable-store.com
Mar 09, 2018 | Nissan Cars & Trucks
- blue message light on top of handset keeps flashing even though all messages have been read - have turned the power off taken batteries out but it still keeps flashing
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 30, 2014 | Lands Phones
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Message light keeps flashing, but no message- Polycom 550
This is usually a problem with the phone's configuration. Is this phone getting it's configuration from a network server or pbx? If so, find the configuration file for your specific extension and find this location. This example is for a phone whose extension is 2704
msg.mwi.2.subscribe=""
msg.mwi.2.callBackMode="registration" msg.mwi.2.callBack="" msg.mwi.3.subscribe="" msg.mwi.3.callBackMode="registration" msg.mwi.3.callBack="" msg.mwi.4.subscribe="" msg.mwi.4.callBackMode="registration" msg.mwi.4.callBack="" msg.mwi.5.subscribe="" msg.mwi.5.callBackMode="registration" msg.mwi.5.callBack="" msg.mwi.6.subscribe="" msg.mwi.6.callBackMode="registration" msg.mwi.6.callBack=""/>
If you are not using a network-based configuration, the phone's settings can be changed via the phone's internal web server. Open a web browser window and enter the phones' IP address, i.e. http://192.168.1.109. The default user is 'Polycom' and the pass '456'. Go to the links at the top for each line you are using and scroll to the bottom, you will see the voicemail settings there. Use the above info to fill in the correct info, save the settings and the phone will reboot.
Feb 23, 2011 | Polycom IP 550 IP Phone
Olympus 550 UZ battery
you may want to use lithium batteries... i find the rechargeables in most cameras to not last as long... also you may need to clean the contacts in the battery compartment with alcohol and let air dry
Jan 04, 2009 | Olympus SP-550 UZ Digital Camera
Flash 550 lcd screen lighs up but will not fire the flash
$300. ? To REPAIR? Way out of line. Replace the unit with a similar flash or go for another brand. SUNPACK flash units are reasonably priced and the have models that work with Canon abd orher cameras.
Ed
May 29, 2008 | Canon Speedlite 550EX TTL Flash
Vivitar DVR 550 camera not working.
I had the same problem and purchased a new battery to resolve the problem. I also purchased a 110v battery charger for the vivitar 550 camera and recharged to old battery.
Dec 30, 2007 | Vivitar DVR 530 Flash Media Camcorder
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
