Question about MSI Ms-7610 P41t-c31 Motherboard Intel G41
Motherboard msi 7610 ver 2.1
How to change the bios the mother cant boot
  • 47 Answers
To reset the motherboard: set the dipswitches at OC_SW1 to ON-OFF-ON, then clear the CMOS Ram by setting the jumper at JBAT1 to pins 2&3 while the power is OFF. Wait fifeteen seconds,Then return the jumper to pins 1&2 and turn the power on. This will re-set you to the factory defaults. You will need to enter the BIOS and re-configure your hard disk. The manual can be downloaded at ECS's website at: http://www.msi.com/product/mb/P41TC31.html#/?div=Manual
Posted on Apr 20, 2014
How to boot from dvd using MS6590 ver 2.0 with VT8237 controller
Turn the computer off.
Turn the computer on, and look for the message:
Press <BLAH> to enter BIOS SETUP.
Press the <BLAH> key.
Change the "boot-order" to make the CD/DVD the "first" boot-device.
Save/Exit from BIOS SETUP.
Insert the media into the CD/DVD device.
Boot from the media.
Aug 02, 2011 | MSI Microstar KT6 Delta (MS-6590)...
My mother Bord "GA-790FXTA-UD5" NO Booting
I heard that if you are using an X6 Processor you need to have the Bios Updated, From what i have read so far the only way to do that is use a X3 or X4 that is compatible with the current Bios to boot up and update the Bios. This website http://us.test.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=3270&ver=#anchor_os Shows which processors are compatible with which Bios. And of course here is the website for the Bios updates http://us.test.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=3270&ver=#anchor_os
Dec 23, 2010 | Computers & Internet
I have an msi ms-7390 k9n sli ver 2 motherboard and I updated the bios to the latest ver. 1.2. After that when cold booting the motherboard does not initialize usb you have to press delete to enter setup...
move the sata connection for your bootable HDD to another port like 3 or 4 and the bios will detect then run bios setup to boot from the sata 3 or 4 and it works like normal, must be a bug in sata 1 and 2. had same issue trying to install win7 x64. Win 7 refuses to detect sata DVD drive, moved it on the MB and it installed fine.
Jul 19, 2010 | MSI K8N Neo4-F Motherboard
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
MSI K8MM-V motherboard doesn't work after BIOS update
First of all never update or install the new bios.. plz let it be geniune .. another thing is that you have to now do the following which might help.. not sure but should
  1. Open the case
  2. look for the jumper on the mother board.
  3. when found take it out
  4. and the reboot or boot your machine
  5. then check if bios options and windows have started
  6. if windows does not appear then install new OS recommended windows 7.
  7. after this plug the jumper back into the motherboard back.
Now this won't work then it can posibly have damaged you motherboard...
Jun 23, 2009 | MSI K8MM-V Motherboard
I need ms-7267 ver 4.2 drivers
I want to download driver mother board ms-7267 ver:4.2
Jun 07, 2009 | Intel Motherboard
I want a sound driver for MSI mother board MSI N1996 (MS 7101 VER 2.B) and thanks for all.
MSI's website has drivers for your board.
Try this link
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=190
Let us know if you run into any bumps
Apr 16, 2009 | Intel Motherboard
MSI MS-6541 Motherboard drive
i need sound driver of mother board motherboard MS-6541 VER :1.0
May 09, 2008 | MSI MS-6547 Motherboard
Mother board driver issues
Don't panic. If you take the cover off the side of the computer and look at the motherboard you will find a jumper that says cmos. You can switch the jumper and wait a minute or so then switch it back and it will boot up its defaults. If you cant find the jumper just take the battery out of the motherboard and wait a couple minutes and then put it back in. that will do the same thing and it should boot up fine.
Mar 02, 2008 | Intel Motherboard
MSI Ms-7610 P41t-c31 Motherboard Intel G41 Logo
589 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
