Question about KitchenAid KUDS30FXSS Builtin Dishwasher
Not cleaning the washer will not clean the dishes the water is not comming out hard enoght
  • 677 Answers
SOURCE: HElp Dishes not coming clean
www.dishwasherfilter.com has a great new product out that filters the water going into your dishwasher. it reduces minerals that cause that white build up or residue. it goes under the sink and doesnt take up much room at all. my dishes looked terrible until i put this filter in. it is very affordable and works great.
Posted on Apr 03, 2008
SOURCE: Dishwasher not cleaning dishes. Casade cleaner not disolved.???
KITCHEN AID DISHWASHER- SOAP REMAINS IN DISPENSER
Posted on Jun 29, 2008
  • 4088 Answers
SOURCE: Upper rack is not cleaning.
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Posted on Aug 15, 2009
heatman101
  • 43501 Answers
SOURCE: dishes on top rack not getting clean. Actually
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 15, 2010
Macmarkus
  • 2605 Answers
SOURCE: dishes in top rack of
Welcome to FixYa.
There likely is a blockage in the filter/screen and chopper assembly below in the sump well, it's just not obvious/visible. The place to look for a remedy is the wash pump area, you`ll need to follow these steps to clean it.
This is why the top rack is most effected, poor water circulation.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Jun 06, 2011
White powder in washer after clean cycle
If you live in an area with hard water, the white powder is probably hard water residue / deposits. Most detergent does not clean hard water deposits anymore because there are new laws that required a change in the ingredients of dishwasher detergent. Here's a product that was created to solve this exact problem. Add about 2 tablespoons to your normal detergent. It's all-natural & made from dehydrated orange peels! They will send a free sample if you ask for one. www.CloudyDishes.com
Hard Water Stains Cloudy Dishes Dishwasher Detergent
May 05, 2014 | Maytag Bravos MTW6600T Top Load Washer
Dishwasher gdwf16ov40ss
Might be one problem causing both symptoms. Do your "clean" dishes have a cloudy white film on them? If yes, you probably have hard water. The hard water deposits can clog your machine AND leave your dishes looking dirty. Here's is a link to a map showing the regions of hard water:
http://www.citriclean.net/why-citriclean/
Jan 04, 2014 | managemylife.com
Wont clean dishes,white streaks in washer,foggy glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Feb 17, 2010 | Viking DFUD04 Built-in Dishwasher
When i do a load of dishes in my dishwasher it is
turn up your rinse aid-and make sure your filter is clean
Oct 27, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have a frigidaire dishwasher and it is not cleaning the dishes good. I ran it twice and there are still some dirty dishes mainly glasses. Also it doesn't look like alot of the dishwasher detergant is...
Have you ever used TANG DRINK to clean out you dishwasher. Empty a whole jar in washer and let run through the hottest cycle. This should clean all your jets
Aug 04, 2009 | Frigidaire 24 in. GLD2250RD Built-in...
Poor cleaning leaving deposits,dishes feel dirty
The problem for the spots is hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Aug 04, 2009 | Thermador DW44Z Built-in Dishwasher
If you are using a name brand powder detergent and still getting the film, the next most common cause is a failed heating element.
Even if the water filling the dishwasher comes in at 120 degrees (f) but the time the powder is released from the dispenser, often the entering water is not hot enough to desolve/activate the powder.
I bet replacing the element will fix you right up!
Apr 05, 2009 | Roper RUD3000GQ Dishwasher
Kenmore Dishwasher
the problem is hard water. go to www.dishwahserfilter.com and get the difi filtration system.
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
KitchenAid KUDS30FXSS Builtin Dishwasher Logo
44 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
