Question about Blaupunkt San Remo CD31 CD Player
Remove balupunkt san remo cd31
Tools
Where is reset button on blaupunkt san ramo cd31
There is no such button to this set. You have to enter its service mode to do this. It is a semi-skilled work. Contact any service technician. Gopakumar Gopalan Google
Jun 05, 2014 | Blaupunkt San Remo CD31 CD Player
It appears CD ERROR every time i try to play a cd...it spins, but after 5-10 seconds it stops and the error is displayed.
If you've tried more than one cd that you KNOW works with other cd players, the sensor in the cd player could be dirty or damaged. If it's dirty, carefully clean it. If it's damaged, it will need to be professionally repaired (unless you're feeling very brave...).
Mar 03, 2011 | Blaupunkt San Remo CD31 CD Player
After 5 years with no problems, my blaupunkt San Remo CD32 started to act weird. Got into demo mode, has continuas display blackouts, etc. I suspect it must be related to the control panel because...
Check the contacts on the back of the display unit and on the front of the radio with the control panel removed...they should be clean looking...try to use an eraser from a pencil to clean the contacts...if this doesn't work...you may have cold solder joints inside the unit due to vibration and the heating/cooling cycles. If you know how to solder, you can check the solder joints to see if they may be bad...a cold solder joint looks like it has cracks in it. Where as a good solder joint should be clean and shiny with no cracks...make sure to use ROSIN CORE solder as this is the only type used for electronics...ACID core solder will render the unit totally useless...
Jan 03, 2011 | Blaupunkt San Remo CD32 CD Player
Please tell me if San Remo CD32 Blaupunkt have or not CODE Password.
According to my database the SAN REMO CD32 (model number 7 641 160 310 ) is NON CODED
Dec 21, 2010 | Blaupunkt San Remo CD32 CD Player
User manual for san remo coffee machine (Capri)
i have one. Can send it to you . I am from holland
Jul 19, 2010 | Coffee Makers & Espresso Machines
I need to remove my timing belt on my e z go golf cart
You have to pull the clutch, remove the cover, losen the idler pulley, move the pulley to give slack in the belt, install new belt. You align by using the key-way grooves in the cam and crank shaft. Both should point straight up.. once on, lossen the bolt on the idler pulley and let it go tight, and then tighten the nut.
Sep 02, 2009 | Garmin BLUECHART G2 2EU466S GOLFE DU LION...
My sercuity code
What it is? You "just" need the security code for this player. If you have the code, you can put it in and the player should work. A manual how to input the code is in the faqs of Blaupunkt. I remember, that you have to press the first station button as often as the first digit of the code says. The same with station button two and digit two and so on.
By the way, I also need the code. I bought my car used and I didn't get the code with the car. But the player is still working without code.
Feb 17, 2008 | Blaupunkt San Remo CD32 CD Player
Blaupunkt San Remo CD31 CD Player Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
