Question about Dirt Devil Featherlight Bagless Upright Vacuum
Vauxhall vectra c automatic gearbox filter where is it
My vacuum is an Electrolux model el 20 the power head stopped working and has a flashing red light on it now
No Owner's manual? Try manualslib.com
But wild guess is the filter bag or possibly the secondary filter is
full. Sometimes. the effect of the full bag will pop open the latch for the filter bag and as a result, will automatically stop. Otherwise, it may be that the motor has overheated as a result of the full filters and stopped due to the overheating.
Mar 26, 2015 | Electrolux Vacuums
A friend who bought a multimaster less than a year ago has had his start a loud 'clattering', dry, noise, and the gearbox started to get hot. The output shaft now has about the same amount of slop as the...
Fein is an excellent tool and has an excellent warranty that will be void the moment you open the gearbox. I do not recommend this action. Fein is quick and responsive, especially for a less than one year issue. Farmerbear at FixYa.com
Sep 30, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
DOES A DYSON HAVE AN AUTOMATIC SHUT OFF VALVE
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
It cannot be reset manually.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Apr 07, 2010 | Dyson DC07 All Floors Bagless Upright...
New Filters have been fitted on the Sebo automatic XI
OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on and look to see if the brush roller is revolving - KEEP FINGERS and all loose items WELL CLEAR. Does the brush revolve? Then, with the machine switched off and unplugged, see if you can rotate the brush roll by hand. Does it revolve easily, or is there a lot of resistance? Then post a reply here saying what you observe. I'll get back to you when I've got your reply.
Feb 24, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Kirby G5 gearbox clicks, why?
most of the time the small fork that comes off of the transmission and connects to the top slide wears out which doesnt allow the transmission to engage properly
Oct 10, 2009 | Kirby G5 Bagged Upright Vacuum
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
The automatic shut off
Check the filter on the inside of the lid for the dirty water tank. It needs to have a 1/4 in. gap from the top of the lid to the top of the filter.
Oct 13, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not working
go to thehooverstore and do a search for your machine. they have exploded diagrams for most of hoover machines
Sep 11, 2007 | Hoover F7431-900 SteamVac Vacuum
Dirt Devil Featherlight Bagless Upright Vacuum Logo
12 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
