Question about Technics Audio Players & Recorders
Technics F61 error, can you please tell me what this means?
I switch the unit on, it displays the error and then switches off
  • 4,234 Answers
F61 is the "shorthand" for protection mode for Technics units. Either the regulator IC or the output AMP-PAC IC has failed. Expect a parts cost between $40 -$100 for the repair depending upon which IC has failed.
Dan
Posted on Jun 22, 2009
Is not work it is show f61 what dos this mine and how to fix it
The F61 error on Technics audio equipment will depend on the type of unit. However, it could be a problem with the power amplifier IC or with the cooling fan. (If it's the fan, you might be able to clear the error by pressing and holding the power button until the fan starts to spin.)
Please add a comment with the model number of your audio equipment for more information.
I hope this helps.
Apr 05, 2015 | Technics Audio Players & Recorders
I have a technics stereo but f61 error on it how do i fix it
F61 is the error code for an amp problem. It may need an amp IC replaced, or, if you're lucky, the may just be bad solder connections on the amp IC's and regulators that are on the heatsink. Most of the technics receivers had an access panel that can be removed from the bottom of the unit, and then you can visually inspect for any bad connections. Check anything that is on the heatsink as these were the biggest problems for this line of receivers.
Dec 18, 2012 | Audio Players & Recorders
My technics hi-fi separates sL-EH790 is not coming on just saying f61 then going off
Hi Shelly,
"F61" is an error code for short and/or overload detected by the processor upon self check.
First thing you have to try to eliminate this kind of symptoms is by disconnecting all of the inputs and speakers connected from the unit then turn it on without them. Let me know if the symptoms still persist...
Jdvillanueva
Oct 22, 2011 | Technics Audio Players & Recorders
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
F61 error
The F61 error indicates that the unit is in "protect" mode. This means that an error condition was detected in the amp section and the unit has shutdown. This is usually caused by a defective amp chip. Expect a parts cost in the range of $60-$90.
Dan
Dec 05, 2008 | Panasonic SC-AK17 Shelf System
Error F61
I have just struck this problem on a friends unit and here is what I did
Disconnect DVD player and all accessories and connections
Problem still occurs
Open machine ( remove three screws from back and slide top cover off. inspection of the inside top cover shows a black patch just above the fan unit
manually spin fan
power up unit and f61 no longer shows up
I think this miaght be a problem with the fan not spinning up at start and the machine then shuting down
I will fit a new fan and see what happens
Dec 05, 2007 | Samsung HT-DS610 System
F61
Hi, I'll quote directly from the service manual Error display - F61 Problem condition - When POWER is switched on, power become off automatically. During normal operation, if DC DET become L, PCNT shall become L and the error display on the left shall be displayed. (IC501) What *I* think that they are trying to say is that the protection circuit will activate if DC appears on the speaker terminals. IC501 the audio output chip may be faulty.
Feb 06, 2006 | Panasonic SC-AK300 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
1,048 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
