Question about Vacuums
Bissell Proheat 12 amp shampooer with no suction
This shampooer put down a lot of soap and water, brush works fine, but then won't **** any of the water up! I got on Bissell's website and checked everything they suggested. There is good suction on the little opening on the right of the machine - the one that gets covered by the red filter - which I cleaned. But when I put the tank on securely, it doesn't translate into getting suction from the floor up to the tank. I had a bit of success by pressing down hard on the base with one hand while trying to push with the other but even that stopped. I have cleaned everything and it just seems to me that some of the suction on that hole is leaking out of the right side rather than pulling air up through that wide **** at the floor. This machine isn't very old or used but was given to me by a friend who didn't need it and I don't have warranty information on it - and am a good 70 miles from a repair shop. Wet soapy floor means I just moved the dirt around! Help!
heatman101
  • 43501 Answers
SOURCE: MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ffuutr
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
heatman101
  • 43501 Answers
SOURCE: Bissell won't release soapy water solution
heatman101
hjf
heatman101
  • 43501 Answers
SOURCE: general assembly for bissell proheat shampooer
heatman101
6wywe
heatman101
  • 43501 Answers
SOURCE: bissell proheat 2x won't release soap water
heatman101
tyu8
Very little suction leaves rug wet.
Check tank and tubes for clogs. Make sure your belt and brush are working. Also make sure you are not overfilling your tank.
Proheat 2X Shampooer Shampooer Parts
800-775-6586
GoodVac com
Feb 24, 2015 | Bissell 2X Proheat 9200 rug cleaner
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x won't release soap water
heatman101
tyu8
Jun 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Proheat Plus turbo brush does not work.
No water or soap is coming through, what do I do?
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
211 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
