Question about Samsung HT-F4500/ZA Home Theater System Blu-ray 3d - htf4500/za
Protection on and off - Samsung HT-F4500/ZA Home Theater System Blu-ray 3d - htf4500/za
What are the limitations for configuring link aggregation and protection on the ETHA, ETHB, and GIU boards?
The ETHA board supports only intra-board aggregation groups and protect groups, but does not support inter-board aggregation groups or protect groups. In addition, the ETHA board can be used for cascading but not for upstream transmission.
The ETHB and GIU boards support both intra-board aggregation groups and protect groups, and inter-board aggregation groups and protect groups. Inter-board aggregation groups and protect groups can be set up only between the ports on the boards of the same type. For example, a port on the ETHB board and a port on the GIU board cannot form an inter-board aggregation group.
When setting up an aggregation group or protect group, pay attention to the following points:
· A port can be directly added to a protect group. Or, it can be added to an aggregation group and then to a protect group. A port that has been added to a protect group, however, cannot be added to an aggregation group.
· Switching is of low efficiency between the ports that are in a protect group only, but switching is highly efficient between the ports that are both in an aggregation group and in a protect group. In this case, it is recommended that you add ports to an aggregation group and then to a protect group. This shortens service interruption.
Jun 07, 2016 | Computers & Internet
Tip
How to Enjoy DRM Protected Music
To enjoy DRM Protected Music, you should remove DRM protection from the music files first. This article contains three parts:
Part 1: What's DRM
Part 2: Why need to remove DRM
Part 3: How to remove DRM from protected music
Part 1: What's DRM
DRM, Digital Rights Management, refers to a range of access control technologies that limit usage of digital media or devices.
Part 2: Why Need to Remove DRM
DRM protection has been used by some big companies to protect their intellectual property rights, such as Sony, Apple Inc., Microsoft and so on. Music bought from different companies will have different DRM protection that can restrict you from playing songs on incompatible players. So you just can't copy your DRM protected music or share DRM protected music with your friends. There comes the headache of removing DRM protection before you enjoy DRM Protected Music!
Part 3: How to Remove DRM from Protected Music
Following is the step by step guide to help you remove DRM protection then you can enjoy DRM protected music freely!
Step 1: Add files
Free download Aimersoft Music Converter and run it. Then click "Add" to load your DRM protected music files.
Step 2: Output settings
Click the "Setting" button to set the music output format as you like:
Step 3: Start to remove DRM from protected music
Click the “Start” button to start to remove DRM from protected music files, that's all.
OK! You have finished to remove DRM from protected music files and now you can enjoy DRM protected music freely!
Note: With this music converter, you can also convert M4P to MP3, M4P to WMA, WMA to MP3, AAC to MP3, etc.
more information: music converter media converter
Connected information : dvd to ipod touch dvd to iphone video
on Jun 03, 2010 | Computers & Internet
What is protective eyewear?
Protective Eyewear is any kind of specially designed gear that protects the eyes from damage. This can include all kinds of threats such as extreme weather, chemicals, sporting injuries etc. And includes things such as sunglasses, safety glasses and swimming goggles.
Hope this helps :-)
Jul 15, 2013 | Work Safety
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
Write protected 4 GB GENX USB
I ve a 4 GB genx USB that.It become write protected. How do I remove the write protect so i can reformat it? The device doe't have a write protection switch. What's wrong with it?
Jan 16, 2010 | Electronics - Others
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 | Cameras
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Protective gear safety
ALWAYS wear protective clothing, including: * Leg protection such as chaps, leggings or cut resistant pants. * Hard hat if there's any material overhead. * Gloves or mittens with an enhanced gripping surface. * Eye protection with side shields. * Hearing protection such as earplugs or earmuffs. * Boots or shoes with steel toes and nonskid soles.
Aug 27, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Samsung HT-F4500/ZA Home Theater System Blu-ray 3d - htf4500/za Logo
378 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
