Question about Hardware & Accessories
Need parts for overlane ball returns AMF
We need parts for amf model # 82-74 ball returns
  • 52 Answers
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
Posted on Dec 30, 2009
HVACjake
  • 22 Answers
SOURCE: I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Posted on Jan 21, 2010
  • 52 Answers
SOURCE: i have a amf paragon model 4004-20 time switch
check the uniline website
Posted on Feb 26, 2010
  • 52 Answers
SOURCE: Where can I get 2 timer pins and 2 timer pin stops
www.electricalexpeditors.com
Posted on Aug 05, 2010
SOURCE: AMF Model No. 7008-00 How do
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Posted on Sep 22, 2010
AMF 82-70 pinsetters
What make, model and year is this vehicle?
Oct 22, 2016 | Cars & Trucks
Need trippers for older unknown model number amf paragon pool timer. timer is 15 - 20 years old
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Jul 21, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I need to order parts. I believe they are timer pins, but not sure. I cannot find a picture to verify that's what I need.
If I understand you correctly, these are the movable / adjustable parts that are placed and secured at the time of day an "on" and "off" operation is to be performed. Most brands of timers use two similar yet different types of trippers. One type performs an "on" function and another performs the "off" functions. They may be color coded or have some other distinguishing mark to differentiate between the two function types. The AMF Paragon 7008-00 uses black and silver to indicated off and on, respectively.
There are several terms used for these parts; "trippers" or "dogs" are the most common - but there are others. Some people even combine the two above to something like "trip dogs" too. Of course, timer pins also convey the part that you're speaking of just as well.
A larger picture with the black and silver trippers installed can be seen easily below:
I hope this helps - please rate this reply - thanks!
Dec 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Our church hall heating is controlled by an AMF time control - no model number. The 7 day setting needs silver metal 'A' tags for 'on' and black metal 'B' tags for 'off'. The cleaner has removed the spare...
You have a 7000 series timer. Use part number X4299 for a set (qty 6 on and off) of trippers.
Both the 7000 series timer and it's associated trippers are now obsolete but you can contact one of the following to see if they still have stock on these trippers.
Grainger 800-323-0620 http://www.grainger.com
Graybar 800-472-9227 http://www.graybar.com
Johnstone (503) 256-3663 http://www.johnstonesupply.com
Munroe Electric 800-777-0172
Atlanta Supply 800-972-5391 http://www.atlantasupply.com
Westside Wholesale 1-877-939-7979 http://www.westsidewholesale.com
Good luck
Mar 28, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I need an owners Manual for a 1976 AMF Slickcraft 24 foot boat
good luck AMF american molded fiberglass went out of business several years ago.
Mar 17, 2010 | Boating
Jan 14, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Hardware & Accessories Logo
32 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
