Question about Plumbing
Shaft seal need changing - Plumbing
2 Suggested Answers
bowtie35278024
  • 1619 Answers
SOURCE: How do I change axle shaft seal?
The seal is easy compared to the axle removal. It is simply knocked into the transmission housing.
Posted on Jun 11, 2015
Replace rear seal (drive shaft) on manual trans and started leaking badly
Drive shaft have only one seal and seal rear side on metal bush
1 jak up littil gear box because after shaft remov ing time oil no feldown
2 remove drive shaft rear bolt
3 mesher drive shaft seal touching area
4 mesher drive shaft Bush touching area this area damage want send machine Shoppe bush cover and drive shaft that time send seal also
Damege change that Bush also
Apr 25, 2016 | 1998 Isuzu Amigo
Jun 11, 2015 | 2003 Nissan Altima
Replacing rear seal on autamatic transmission
with the drive shaft out take a large enough slotted screw driver and pry the seal out of the tailstock, be carful not to damage the tailstock surface. to install new seal take a hammer and tap the seal in place evenly until flush.
Sep 06, 2014 | Cars & Trucks
I have a slow oil leak on my toe shifter
hi there sounds like you have a weeping seal that stops the oil going past the shaft these get hard a worn or cracked easy fix take off the gear change lever ,then the cover then you should be able to see the seal arond the shaft,then you should see the oil leaking get a bent screw driver or proper seal remover and remove then clean in the hole place seal loctite onto the outer surface of the seal then find the old seal if not too bent out of shape to use to knock the other seal in noting not to damage new seal,if leak persists then the shaft maybe worn which this will need replacing . hope this helps
Sep 22, 2013 | 1999 Suzuki VZ 800 Marauder
Axle seal keeps leaking
Most likely you need to replace the axle shaft.
Jun 22, 2017 | Cars & Trucks
Oil is leaking out of the shifter assenbly on my 2001 yamaha yx 125. there appears to be some type of seal there. how do i change it?
Most often, the shifter shaft seal is on the inside of the left-side engine/transmission cover. Check this with your repair manual. If so, you would need to remove the shifter assembly from the shifter shaft and then remove all the machine screws that hold the cover on and remove the cover (sliding it off the shifter shaft). If this is the case, you will also need a replacement cover gasket in addition to the shift shaft seal and it will be much less messy if you drain the engine oil first. Also, take care in re-installing the new seal and wrap the knurled end of the shifter shaft with tape prior to sliding the cover back on so it doesn't damage the new seal.
Jul 09, 2009 | 2003 Yamaha YZ 125
Rear drive shaft seal leaking
Yes, but you will need to mark the yoke position and exact number of turns to remove the nut or you will change ring and pinion gear lash setting when re-installing it. You can use a large pipe wrench to hold the yoke still while tightening, or get a special tool made for that.
May 04, 2009 | 1998 Ford F150 Regular Cab
Grease leak toyota 4runner 1996
You need to disconnect the rear wheel cylinder brake line and pull off the rear backing plate, via the 4 bolts that are visible after you remove the brake shoes. One the backing plate is loose, take it down, out of the way, and pull the axle shaft straight out. You will need several parts from a Toyota Dealer, and a machine shop to press off the old bearings and seals, and to press on the new bearings and seals. Go to the dealer & tell them your problem, we do this job once-twice a week; a common issue. The only seal that you can change yourself is the axle tube "outer" seal, you will see it when you pull out the shaft. But, this seal is not the cause of your leak. The inner seal on the shaft is worn. You will also need to replace the oily brake shoes, too. Hope this helps. A FIxYa rating would be appreciated.
Feb 26, 2009 | 1998 Toyota 4Runner
Loosing oil on the output shaft of the transfer case, I changed the seal two times it's still leaking.
You may have pressure build up in the tranfer case and its going out the weakest spot which is the seals.Who changed the seals?Your transfer case may have a blocked breather if fitted
Oct 20, 2008 | 2004 Jeep Grand Cherokee
Plumbing Logo
24 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
