Question about Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer
GC420t, Alternate blinking of RED and Green, not printing
After power on the printer, the printer is completing POST and blinking RED and Green, Firmware also downloaded, but still same problem
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: printer erorr after down load of firmware
The printer probably failed in the final phase of download firmware.
After eight hours it is clear that the firmware setupwas not successfull.
This may have damaged the printer.
Keep the on button pressed for ten second, see if the printer turns off.
Try unplugging printer power cord, leave the printer unplugged for thirty minutes or so.
If the printer does not restart, the firmware inside the printer had been damaged.
In this case call the support number listed on your user manual.
If printer restart upgrade firmware again.
Posted on Sep 09, 2008
IrishDruid
  • 2712 Answers
SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Oct 23, 2008
My printer gc420t give me red light error after one label print plz tell me how to solve this..i bougth new printer
Original printer may need to have the software reset or it may have a physical issue in the drive causing the printer error.
Sep 06, 2017 | Light Office Equipment & Supplies
Gc420t red light
Call for tech support.
Apr 16, 2014 | Office Equipment & Supplies
Repair ip3680 error
the printer has occurred. error code 006.
Nov 24, 2013 | Canon PIXMA iP3600 Photo Printer
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Alternate red light blinking of ink and paper botton
saw this on the internet too...
http://www.sscllg.com/epsone.shtml
2. In Configuration tab of the SSC window, select your installed Epson printer and Printer Model
3. Plug-in the printer to your PC and turn the Power On.
4. In your tray, right-click SSC Service Utility, go to Protection Counter, then click Reset Protection Counter.
5. A dialog box will appear, just click Yes.
6. Right-click SSC again in your tray, go to Extra, click Soft Reset. Then say Goodbye to the annoying alternating red & green lights.
Jan 05, 2009 | Office Equipment & Supplies
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Blinking Lights
Do you have a paper jam? If nothing is wrong it may be internal hardware error. Call Samsung for help.
Apr 04, 2008 | Samsung ML-2510 Laser Printer
Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer Logo
146 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
