Question about Sport & Outdoor - Others
Instructions blagdon amphibious p9000
Pump blows fuses
I use Rocstor amphibious-x7 but i forger password so ineed password reset way.. Please help me
These are probably one of the most secure devices around. I think you are out of luck. Try contacting Rocstor directly.
Nov 05, 2014 | Rocstor Amphibious X7 1 TB 2.5" External...
Caprice classic 1991 model fuel pump will not come on. fuse mounted underhood next to ABS relay blows upon contact with circuit
e fuel pump motor may have failed, causing a short and blowing the fuse. Try unplugging the fuel pump connector at the pump, then turn key on with a new fuse in place. If the fuse blows again, it could be a short in the pump's wiring. If the fuse doesn't blow, it is likely a bad pump.
Nov 14, 2012 | Chevrolet Cars & Trucks
Blagdon 6250/backwash instructions
Turn off the pump.Ensure a hose is connected to drainage on the waste outlet of the valve assembly. Make sure there are no kinks in the hose.Turn the valve to "backwash" (usually opposite of filter).Turn the pump on and run for 2 min.Turn off the pump and run on rinse for 15 seconds.Repeat until the glass jar on the waste line runs clear during backwash.Return to filter. (If you have a sand filter, your done. If you have a DE filter, add the correct amount of DE to your skimmer return while the pump operates. An 18X34 pool takes about 5-7lbs.)
May 09, 2012 | Pool & Spa
I have an Invacare P9000 XDT wheelchair. I keep getting flashing lights 8 times, indicating controller fault E08. I have extra parts I got from a junk yard but still get the same fault everytime. I've...
Hi DREADFULPCBU
There isn't much to the P9000 joystick and controller. First and formost have your batteries load tested to ensure you have 24 volts dc. That in itself may solve the problem. I would then check each and every wire connection to make sure there is good continuity on all metal connectors. Check the voltage to ensure ther is only 24-27 volts dc. You could also have an over voltage possibly caused by a short somewhere. Has your chair ever gotton wet? If so one of the motors could be shorted out. Test this by taking out the motor brushes (one at a time) .See if it has water or oil on it. If so you may need to replace that motor. If all that is ok then here is where you can send your joystick and controller for repairs. ( I'm not confident that the ones you got from the junk yard are good.
PG Drives Technology Inc 2532 East Cerritos Avenue
Anaheim,
California 92806-5627
USA
Tel: +1 714 712 7911
Fax: +1 714 978 9512
www.pgdt.com
Good Luck
mimobility
Apr 30, 2011 | Invacare P9000 Xdt Motorized Wheelchair
Where can I find the pin out diagrams for a P9000 XDT motor so that I can ohm it out?
Chairs with motors that have a rectangular connector are what I am going to describe.
There are two round pins in the center of the motor plug. These two are for the brake coil. Ohm readings should be between 40 and 80 ohms. The motor reading is takin from the contacts on each side of the brake pins. Should ohm between 0.5 and 5 ohms.
Mar 15, 2011 | Invacare P9000 Xdt Motorized Wheelchair
Keeps blowing fuel pump fuse. Why?
This normally happens due to short in the wirings.Or if someone has connected a stereo or some other electrical contrivance to the wiring harness (bundle), either under the dash or under the hood.To confirm this unplug the fuel pump wiring connections and insert new fuse.Then start the car and see,if still the fuse blows then its a short in wiring.But if the fuse does not blows then its faulty fuel pump relay or faulty fuel pump itself.So first replace the fuel pump relay and see,if the fuel still blows then its faulty fuel pump.But if the fuse not blowing then relay was the faulty part.The fuel pump relay located on the fuse box under the hood.---------This troubleshooting tips will help you locate the fault and solve it.-------Thanks.Helpmech.
Dec 13, 2010 | 1996 Dodge Neon
Fuel pump fuse keeps blowing?The fuse is by the right front of radiator.
FUEL PUMP WIRES HAS A SHORT OR FUEL PUMP BAD SHORTING OUT.BLOWING FUSE.CHECK FOR SHORT AT FUSE BOX AND AT THE FUEL PUMP WIRES.THE PCM GOES BAD SOMETIMES IT WILL SHORT OUT BLOW FUSE TO FUEL PUMP.
Apr 14, 2010 | 1992 Oldsmobile Cutlass Ciera
Sport & Outdoor - Others Logo
15 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
