Question about Quietside Multizone Inverter Duty Mini Split Heat Pump 24K System QSVMO-24A
How to stop the unit from only blowing cold air
Our unit is only blowing cold air we have it set on warm it showed a E4 code
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
Getting an E4 Code and the air is not as cool as the temperature reading indicates. How to fix?
I think it is low on gas. You will have to call the repairman on this one. If it is real old, just replace it.
Jun 09, 2015 | Heating & Cooling
It seems the compressor is not switching on the air con blows cold air but not as cold as it should be. It shows an E4 on the display.
Is this a house, a car, a portable AC? We can't help you look up error codes without a model number. Details pls.
Sep 25, 2014 | Heating & Cooling
A/C Blows warm when idle
I can't say much without having the actual code.
When the ac stops blowing cold at idle, the most common reason is not enough air flowing thru the radiator, or the radiator fan is not running and the only air flow is when the vehicle is moving.
May 09, 2013 | 2005 Chevrolet Colorado
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
2002 bmw 3 series intermittent ac
Sounds like a compressor problem.
Jun 05, 2009 | 2001 BMW 325
My domain air 2.65kw portable ac unit - E4
Make sure the filter is clean and the pump is operating.
Mar 08, 2009 | Heating & Cooling
Centrex airconditioner
I bought a house with one already installed. Found that it isn't switching from 'hot' to 'cold' After time the unit will beep and flash LED's on the unit itself and then switch off. Rather handy on 40 degree days. Good luck sourcing parts for the unit as the company have gone bust. I do know an honest working fellow that installs units - he suggests that Kelvernator are a no go, Mitsubishi, Panasonic are the ones to look at. Pay the extra cash for a brand name, they're less likely to go bust for a start, and if there is a problem, parts are readily available.
Jan 06, 2008 | Heating & Cooling
Centrex split system air conditioner
I have a centrex split system which the inside unit is working but the outside one the motor is not working does anyone know why and where can i get parts from sice centrex no longer exists..
Nov 18, 2007 | Heating & Cooling
Quietside Multizone Inverter Duty Mini Split Heat Pump 24K System QSVMO-24A Logo
Top Quietside Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Quietside Pool and Spa Expert? Answer questions, earn points and help others
