Question about John Deere Muffler 1010 Diesel Tractors
John deere 655
Hi, have a old JD 655 that was running fine when it lost all power and sounded like it was about to die so I switched off and as fuel was very low assumed that it was about to run our of fuel. Filled up, but now it wont start. Turns over but just doesn't fire. Have checked battery and it appears to fully charged. Can hear the fuel pump making a noise when I get ready to try and start it but just 'spark'/fire. help thanks
  • 17 Answers
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Posted on Nov 17, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Posted on Apr 25, 2010
  • 146 Answers
SOURCE: Lack of Spark
If all of your tests are correct, the thing remaining is the ignition coil. A bit of a pain to get at and expensive too. Parts diagram here. Before you buy a new coil, see if there might be just a broken spark wire or loose connection at the spark plug contact end.
Posted on Jul 17, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
  • 6468 Answers
SOURCE: Our John Deere 160 lawn mower wont start. Installed new carb, fuel filter, battery. Has spark but wont turn over and run.
if the engine doesn't spin look at the starter if it has spark and a new carb is there power to the solenoid on the bottom of the carb does it fire on carb cleaner?
Posted on Apr 30, 2012
My jd 111lawn tractor wont start was mowing it just slowly died.now it will turn over but wont start
Sounds like a fuel issue. Check and make sure your gas tank has fuel in it. Then check fuel filter to see if it is allowing fuel to the carb.
Aug 15, 2016 | John Deere Garden
My 1996 JD 755 diesel loads up and burns black smoke little power
check the air filter ???
check the exhaust ???
possibly bad fuel ???
Oct 25, 2014 | John Deere 650 750 850 655 755 855 955 670...
Start motor runs fine then starts missing 6420 l JD
Sounds like a fuel problem. Check fuel lines, fuel filter and carburettor are completely clean.
Feb 25, 2014 | John Deere Garden
My J.D. lx266 rider runs and drives fine until i turn the blades on then it dies. i took the deck belt off and the blades spin freely . do you have any advise for me
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
Aug 10, 2010 | John Deere Garden
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
6330 JD every fuel line leaks with just over 100 hours.
John Deere will replace the lines with the original under warranty but as soon as your warranty runs out and you develop a leak go to solid rubber after market fuel lines and your problems will be over.The braided fuel line that is put on at the factory and replaced by Deere under warranty has a poor performance record and i would replace it,Deere can't get warranty for the repair unless the part replaced has a J.D. part number on it,but if you are willing to supply the hose,go rubber and the leaking will end.
Apr 12, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
John Deere Muffler 1010 Diesel Tractors  Logo
22 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
