My sennheiser ew 100 g2 is muted all efforts to unmute never work while the transmitter device show response of the mic
4 Suggested Answers
  • 11 Answers
SOURCE: transmission distance problem on Sennheiser G2 wireless
I regularly use G2 ew100+300 systems, which have a manual squelch adjustment on the reciever. Squelch is difficult to explain but here we go: a squelch adjustment gives you the options LOW, MEDIUM, HIGH these settings effect transmission distance and interference rejection. for example: a HIGH squelch is less prone to interference but has a shorter transmittion distance. A LOW squelch is more prone to interferance but allows for a longer transmission distance. For most applications, a MID squelch is fine. If this does not help- the next option would be to swap arials between units and see if the problem moves. The G2 series are a 30mw transmittion which has an effective range of about 50m
hope this helps.
Rus.
Posted on Feb 19, 2009
  • 3 Answers
SOURCE: sennheiser EW 100 G2
Warranty? If not, open it up and look for unattached wires. If there's none, look for parts that look damaged, usually brown-ish. if there's any, they need to be replaced. Might get lucky and find parts
Posted on Aug 11, 2010
bobhifi
  • 635 Answers
SOURCE: sennheiser ew 100
Heating up on replacing batteries is an indication of a short circuit.The construction of these cordless mic does not allow one to do any kind of repair. You will have to replace the whole circuit board which is available only with the authorized service center. And might cost you 70% the cost of the mic itself.
Posted on Jul 06, 2011
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows.
RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again.
Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
Sennheiser ew g2 bodypack with shure u2 receiver compatibility: When I tune the frequencies similar to each other, the U 2 gets an RF-Signal, but it doesn`t receive any audio-signal, when i talk into...
Sorry, that will not work. Typically, it is not possible to use one manufacturers transmitter with another manufacturers receiver. The two manufacturers use different tone-key squelch, different noise reduction, and different companding schemes.
Aug 09, 2013 | Shure U2 / 87 With SM-87 Professional...
Issue more complicated than originally thought!
This isn't a solution. But after I've gotten into my microphone with the same issue using a torx screwdriver I found that I (Electrical Engineer) don't have the proper equipment to fix the issue. Roughly 100 dollars (Flat rate) and a send off to Sennheiser is your best bet.
May 22, 2012 | Sennheiser 100/500 G2 Series Wireless...
Sennheiser ew 100 G2 cordless mic shuts off, low batt signal flashes , when fresh batteries are used. batteries inside mic heat up & get hot!
Jul 06, 2011 | Audio Players & Recorders
The ew 3000 iem (brand new) is stuck on mute. Tried everything to no avail. Ideas????? Please Help!!!???!!!!
To get your transmitter out of mute press the standby button and hold it briefly until "RF Mute Off" appears. Your display should change from red to orange and the transition icon will also be displayed again. This indicates your transmitter is transmitting.
Regards, Tony
Mar 24, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
All four hand held systems failed
check out override frecq see if you can change transmit and recieve switch settings ie dip switch sets sombodys overiding your freks
Dec 17, 2008 | Sennheiser Evolution G2 100 Series UHF...
Sennheiser EW 100 G2
Oct 14, 2008 | Sennheiser Evolution 100 G2 (SEN-EW152G2)...
 Grubhead
Grubhead
