Question about Rangemaster Refrigerators
Hood vent damper 8 1/2" not closing - Rangemaster Refrigerators
3 Suggested Answers
SOURCE: Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Posted on Jun 28, 2008
  • 69 Answers
SOURCE: no green light on vent damper
The damper is no longer funtioning and needs to be replaced
Posted on Dec 22, 2008
Damper in vent door opening and closing continuously
the vent damper opens and closes depending on the temperature
inside the fridge. You might try to change the temperature settings in the fridge and see if that helps
Mar 10, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 2003 e350 supperduty v10 van and when driving a/c stops blowing why ? and its not the compressor becuse cold air still blowes out the back vents but not the front vents
Somewhere there is a vacuum or electronic switch keeping the damper closed to the front vents, or or closing the front vents while driving. You need to find what controlls these dampers.
Aug 15, 2013 | Smartdisk - Peripherals - HARD DRIVE,...
We have a vented kenmore range hood that is vented thru a pipe (out the top of the hood) to the outside of the house; air comes out the top of the hood and blows into the kitchen. why is air blowing out...
Sorry to read about your problem, I hope this helps you out.
you may have a clog, in the vent pipe, not uncommon in the winter for wild things to build nest..
their is also a air damper plate, that might be stuck, this damper prevents outside air from blowing back in
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Kitchen Ranges
Hi My extractor hood in the kitchen has a hose that goes into the kitchen roof then out through the roof vents. The problem is that all the cold and wind comes back down the hose and makes the kitchen very...
You need to install a damper. It sounds like your vent now just vents into the attic and out the attic vents. If that is the case, or even if it vents directly to a roof vent, you can install a damper that only lets air flowe one direction.
rewilliams_2068_131005279
springload.gif Here is just one source of many that you can purchse dampers from.
http://www.rewci.com/416splobada.html
The damper would be installed in the exhaust duct. If your vent pipe is connected to a roofmounted vent, you can replace the vent with a dampered vent.
Aug 30, 2009 | Bosch 22 in. PCD685F / PCD685D / PCD682D...
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Range vent damper noise
Check to make sure that the installer completely untaped the damper when he installed it. It needs to be able to move freely.
Apr 04, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
7" damper
The damper you are looking for is Broan part number 97. It is available online.
Jan 17, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
No green light on vent damper
Dec 17, 2008 | Heating & Cooling
Jun 27, 2008 | Broan-NuTone Broan Range Hood Accessory
Wind comes through island hood
Thee is supposed to be a damper in the vent pipe were it connects to the hood. maybe its missing or stuck.
Nov 02, 2007 | Kitchen Ranges
Refrigerators Logo
11 people viewed this question
Top Rangemaster Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Rangemaster Refrigerator Expert? Answer questions, earn points and help others
