Question about Chaintech 9LIF7 i845G Motherboard
PCI Slot 1 (PCI bus 1, device 10, function 0)
PCI Simple Communications Controller in my Device Manager shows a yellow question mark. and then this is the additional info :-
pl guide me what to do ?
I find it difficult to connect to the Internet because of this.
Regards
  • 476 Answers
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Posted on Jun 19, 2009
    New Friend:
How to installed inthernet controller
Posted on Jun 30, 2013
PCI Slot 5 (PCI bus 7, device 0, function 0) Where can I go to download a driver for this network controller on my hp dv2700? This is what it shows up as in my device manager. I've tried using the search...
Firstly you wont get anything searching that cause it is not a model number or brand of a network controller. Look for a yellow question mark or a small red cross under all the devices. If this doesnt work get the program called 'everest' which will tell you the name of your network controller to run your LAN.
all the best
kc
Feb 23, 2011 | HP Computers & Internet
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
PCI simple communication controller not installed.
First u have to install Microsoft Universal Audio Architecture .... that is UAA. then check in the device manager that is under system devices "pci bus" has excl. sign (i.e. ! ). Delete the pci bus device with exlc. sign. and press the button in the upper side of this window "scan for new hardware" it will automatically install the pci bus device and ur sound comes...
Jun 29, 2010 | Intel D845GVSR Motherboard
I82801@P4BGV-MX audio ctrler invisible in devmgmt.msc
open device manager and i m sure that it will be given under system devices because all the devices that does not come under
unidentified devices are in the system devices list check it there or instead use some software like driver detective to find all the devices connected to the computer and get their device drivers
Jul 08, 2009 | ASUS (P4BGV-MX) Motherboard
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
Question Mark in My Device Manager
dear,
pl install 1st chipset dirver from motherboard cd.2nd install vga/video driver,audio driver,ethernet/lan driver.
when require restart pl restart pc.
Feb 28, 2009 | Acer AOpen AW 724 Sound Card
Pci simple communications controller
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Feb 21, 2008 | EliteGroup 741GX-M Motherboard
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Chaintech 9LIF7 i845G Motherboard Logo
7,655 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
