Question about Nikon Speedlight SB-800 TTL Flash
No full power on the light
Flash test don't working when a SB-800 in a normal mode
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Nikon Expert
  • 305 Answers
Be pacific not making sense
Posted on Feb 01, 2015
  • 216 Answers
SOURCE: Nikon SB-800 Failure
Check by testing flash that I've posted on 1/15/08
atdlee@netzero.com
Posted on Jan 15, 2008
bearydude
  • 62 Answers
SOURCE: Broken lcd display Nikon sb-800 flash
You can order the part from NIKON or I can fix it for you .
Berrie Smith Camera Repair
bbmw@bellsouth.net
Posted on Feb 06, 2008
SOURCE: Nikon Speedlight SB-800
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
Posted on Mar 19, 2008
SOURCE: Nikon SB 800 fires but pictures reamain dark
make sure your white balance is set to "flash" on both cameras
Posted on Oct 11, 2008
  • 14 Answers
SOURCE: Nikon SB-800 flash - needs to be reset ?? or repaired ??
Try reseting the flash itself, press and hold the "Mode" and "on/off" buttons together for 2 seconds approx...this should reset the whole flash.
If that doesn't work try unlocking it by pressing the "on/off" and "Sel" buttons together, the padlock should disappear.
With respect to the corroded contacts you just need to try and clean them as best you can...but it sounds like you have really bad contact with the battery and hence a serious voltage drop, hence the dim display and lack of the red ready light.
Thanks
Mark
Posted on Sep 29, 2009
Synchronizing two sb-800s with a nikon d300
You knoq the SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
To access the SU-4 remote mode hold the "SEL" button in for a few seconds until the menu appears. Scroll down to the SU-4 setting and turn it on.
When using this method set the flash to manual and set the power as needed.
Regards.
Apr 13, 2010 | Nikon Speedlight SB-800 TTL Flash
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
SB-800 Stuck in REMOTE
http://www.nikonusa.com/fileuploads/pdfs/SB800_sellsheet_060425.pdf
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
How do I use two sb800 one on the camera and one behind a groups of people to eliminate the shadows on the wall
The SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
Mar 08, 2010 | Nikon Speedlight SB-800 TTL Flash
I have a new D3000 and a nikon SB-600 flash. I
From the Nikon site, do you have one of these flash units.
Support for the Nikon Creative Lighting System when using SB-900, SB-600, or SB-400 Speedlights, or the SU-800 Wireless Speedlight Commander
If so You set the flash mode to "comander" the pop up flash must be UP
This Video by Nikon shows how but you will have to read the manual to get a full description go to the flash section http://www.nikondigitutor.com/eng/d300s/index.html
Then look at them all :)
Jan 21, 2010 | Nikon D3000 Digital Camera
Thanks
Mark
Sep 22, 2009 | Nikon Speedlight SB-800 TTL Flash
Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Apr 18, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
    atdlee@netzero.com
    Oct 22, 2007 | Nikon Speedlight SB-800 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    48 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
