Question about Vacuums
Hoover whirlwind WHS2002 is showering me with dust from front filter
I have just cleaned all the filters etc and it is spraying me with lots of dust and choking up the from filter.No tubes appear to be blocked.
reddevil6
  • 1673 Answers
SOURCE: Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Posted on Feb 21, 2008
SOURCE: filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Filter keeps clogging
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
  • 64 Answers
SOURCE: debris in front of foam filter
when that happened to me it was because the cup got full or was loose. I am now seeing the cup seal, located on the body above the cup, is not sealing and my filter is loaded. That might be a clue.
Posted on Dec 31, 2008
  • 354 Answers
SOURCE: My Hoover UH70040W Wind tunnell
Well if the vac motor is good then its either a clog or a leak ,if you say no clog then it has to be a leak. Make it blow out and see where the air is coming out or try and find it while it is running with a piece of typing paper loosly around the hose and piping. Seals at the connection areas go bad so check them as well.
Posted on Mar 31, 2011
  • 231 Answers
SOURCE: blowing dust out even after cleaning filter
the bagless containers of these vacuums do tend to hold a strong dust odor. the only way ive found to help eliminate it is with a product that i use called FreshWave odor neutralizing pearls. you never want to use fine dust carpet freshener or any product like that cause it will eventually burn up your motor. but if you are interested give me a call and i can ship you some of the freshwave. 703-724-1112
Posted on Apr 12, 2012
Buuld up of ( layers) of dustbon fikter under dirt container happens after 1 hoover
this indicates that the filter is not fitted correctly or is the wrong filter in use
Apr 27, 2015 | Hoover Vacuums
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
I want to check out my Wertheim 3180 my daughter borrowed @ it has lost a lot of suction filters are clean
If the filters are clean, try removing the hose from unit whilst switched on, if the sound changes then you may well have a blocked hose or tube
Jan 12, 2015 | Vacuums
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Loss of suction, sucking air through hole on side of housing. Whats causing this?
The air hole on the side is a secondary air release if the suction is not reaching the dust collector detachable bucket. I had this same problem, if nothing is clogged in the hoses try scrapping all the dust off the cylindar screen filter inside the top of the detachable dust collector, I didnt realize that my filter screen had so much **** on it so I cleaned it off and the vacuum worked like a charm. Now the air can flow through unrestricted.
Mar 03, 2012 | Shark Navigator Bagless Upright Vacuum
Hi, My Electrolux twin clean vacuum has both red and blue lights flashing and I can not get it to turn on to clean the filters. Any suggestions
Try taking the twin filters outside - also take a dustpan brush and tap the filters gently on the bottom, then brush the dust away as it comes out. This can take quite some time, and you will find that LOTS of compacted dust will come out!
Feb 20, 2011 | Electrolux Twin Clean Bagless Canister...
Suction is low, but bucket is not full and filter is relatively clean
The filter may be relatively clean, but if there's a lot of fined dust in your area the pores of the filter will fill and clog fairly quickly. Try replacing the filter and see what happens. If you don't have a spare, consider purchasing one for use while the other is drying out. Then alternate.
A leaky hose could also cause a loss of suction, as could a broke or cracked flex tube (the short piece in the power head).
Aug 05, 2010 | Electrolux Central Vacuum
Loss of performance, belt seems ok filter is clean
the lifetime pre motor filter could be blocked, dust filter (Blue) in the circular housing end of motor housing. or the machine air intake is blocked or the cyclonic chamber needs removing and cleaning. All of the bits not silver grey can be removed take them off and clear out the tubes. If after this it has still got the lack of power the motor may be on its way out (but you would be able to smell it burning) hope this helps
Feb 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
