Roland jv 90
The other day I had static electricity when I touched the key board ( I felt a slight shock). When I began playing my keyboard, I noticed that my programmed sounds in INT A4 Guitar, and INT A7 Steel Guitar were replaced with a tiny piano sound. When I checked the sounds, they now said: "P1 INITIAL (EXP). I don't know what to do. Note: I have both of these sounds on bank B, which is a PCM Memory Card M512e. but when I try to transfer them back into A4, and A7 respectively, it just says Data Error.
  • 209 Answers
SOURCE: sound card
install the driver cd of your sound card prior from this, you should have installed the motherboard cd
Posted on Dec 02, 2007
  • 77 Answers
SOURCE: IBM T30 Thinkpad sound system failure
Thinkpad is a laptop. Very few laptops have "removable" sound cards. Sorry, but I think that applies to you. After opening many different Thinkpads (and the new Lenovo versions) I have never seen a separate sound card... the sound chip (usually AC97 standard chip, or Intel) is integrated into the motherboard. Newer laptops often have one or two small PCI card slots, but this is usually occupied by WIFI cards. Never seen a PCI sound card for laptop mini PCI slots either. HOWEVER, there is one solution available to you: There are many old PCMCIA cards with full Sound Blaster or AC97 sound, that provide excellent 32-bit digital sound. Search in an old used PC hardware bin, or buy a new one on line by searching for "PCMCIA sound card". Prices are very low. Good luck, let me know if you find one, please.
Posted on Feb 04, 2008
SOURCE: sound card
Your laptop should have a sound card built into the board. To make sure, check for three round color coded holes anywhere along the edge of your laptop frame and ports. The Sound output is usually green. The sound in is blue and the mic in is red. If you plug in speakers n the green and don't here music, then check to see your SOUND DRIVERS are installed. If they are not no sound will play. The check for Sound drivers, right-click My Computer, then chose HARDWARE and let it list the components. Any one with a yellow mark needs drivers.
Posted on Feb 18, 2008
SOURCE: Bad direct sound driver
actually u have to tell that which laptop u have is it compac,toshibaa,...etc.go to and write "free sound card for compac'model no.' " ok than they will show u the softwares u have to download it ok bye tc.
Posted on Jun 07, 2008
SOURCE: Roland Juno D Keyboard Keys not sounding
The problem of the Juno-D is de rubber strips inside under the keysthere are 5 strips, you have to clean this rubber strips with alcohol and clean the board too, this will resolve your problem if you leave the Juno-D without playing for a long period you will get the same problem again. this is a very poor keyboard it,s a pitty that Roland Make so poor keyboard!!!!
Posted on Mar 17, 2009
My screen is out on my roland jv 80 keyboard
This problem will require servicing. The screen is bad, and has to be replaced.
Apr 18, 2014 | Roland Music
Roland jv-90 button repair
I.m looking for all the ROLAND JV-90 plastic push buttons.
Jan 10, 2012 | Roland Music
I have a bodyguard t260 treadmill and when I run on it there is a great deal of static electricity that shocks me when I touch the treadmill handles
The shock is a build up of static electricity on your body called Electrostatic Discharge (ESD). Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful or dangerous.
Nov 11, 2011 | Exercise & Fitness
Hello. My mother board do not recognize my key board coorectly any more. It was a static electricity shock. some key is works and some it does not some keys, if I press it, 1/2 of the top line types also....
since you have take the first step by changing the keyboard and it still the same thing, you don't have any option than changing the motherboard. it mean that the board has short circuit on the side of the keyboard and it has affected those component that will make the keyboard to be functioning during the electrical whatever.
please try to change the motherboard may god provide for you.
Jun 14, 2010 | Gateway MX8738 MotherBoard - DAPA6AMB6D5
What causes the static background noise in my keyboard?
It sounds as though you have a static electricity problem in your volume pot. Although there are sprays on the market that you can use for all of the electrical switches on your keyboard which removes and suppresses static electricity, one way to make sure this is the problem is to slide your volume slider to maximum, then minimum, up and down about 10 to 20 times, if the scratchy sound begins to diminish, you knwo the problem lies there. As a matter of fact, if you do it long enough, the sound may go away altogether, although without a good spray of electronics cleaner or electrical contact cleaner (which you can find at stores like home depot or online, even eBay), the sound will return.
If this is not the case, and the scratchy static sound does not go away or depreciate, it could be your cords or even static on the pc board inside the unit. If you are confident that you can crack the case on your board without causign damage, then get a screwdriver and open the case (all screws are located on teh bottom of the unit) and give it a good spraying with electrical contact cleaner on all of the contacts and even a once over on all of the circuit boards. Do not wet the circuit boards with too much spray, rather, give them a light misting.
For areas where you plug in, like your 1/4 inputs, your midi ins and outs, and headphone jack, spray the contact cleaner inside the holes. You don't have to worry about spraying too much in these areas. Just do not oversaturate.
Hope this helps, and thanks for using FixYa
Jul 18, 2009 | Music
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
Dec 16, 2008 | Music
Roland keyboard
You need to clean the pcb and remove dried spillage residue
you could try wasking the rubber contacts but these may need to b ereaplaced.
Jun 28, 2017 | Music
Open Questions:
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
