Question about Nokia Lands Phones
Reset tamburo brithet 7030 - Nokia Lands Phones
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Click on restore to factory settings
Posted on Nov 28, 2014
How to reset drum for brother dcp 7030
Paper Roller( Heater) power supply are dead
Mar 23, 2013 | Brother DCP 7030 Monochrome Laser -...
Messaggio unitafotovoltaica non valida
Prova cosi": pulisce i contatti dove il tamburo si inserisce. Accertati che si fa buon contatto. Se il tamburo e' nuovo, allora, tornalo in dietro al negozio e fati uno scambio.
A proposito, sono americano e ho abitato in Brindisi. Da dove sei tu? joefine48@yahoo.com
Feb 26, 2011 | Xerox Phaser 6110 Laser Printer
How to reset the printer dcp 7030
Hi
you need to replace chips on cartridges with aftermarket chips
Nov 28, 2010 | Brother DCP-7030 Digital All-in-One Laser...
I have a printer dcp 7030 brother company i am showing problem toner life end after reffling
I just had this problem and fixed it. The original toner cartridge that comes with the printer cannot be reset. You have to buy at least one new cartridge. The reason is that the original cartridge that comes with the printer doesn't have a reset flag. You can, however, refill/reset a cartridge that you buy separately. Pull out the drum and lift the cartridge out of the drum. Hold the handle and look on the left end. You should see a crescent shaped hole with a white flag/lever. To reset this, move the white flag all the way to the left (I had to use something to push it). Put it back into the printer and voila - it fixes itself. Then, after the printer has been reset, you can use the original cartridge again, if you want. The flag part won't matter once the printer has been reset. I hope this is clear. I know it worked for me, and I had the exact same problem.
Jul 14, 2010 | Brother DCP-7030 Digital All-in-One Laser...
How to reset DCP 7030 drum unit
Reset DCP 7030 drum unit : -LCD-
Press MENU and turn on printer - MAINTENANCE
arrows 81 and OK -RESET DRUM COUNT
press OK -RESET LIFE COUNT
press CLEAR / BACK
arrows 99 and OK
ready
Oct 26, 2009 | Brother DCP-7020 All-In-One Laser Printer
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
Toner Problem.
Is this a remanufactured/ compatible unit? I suspect that the toner reset lever on the cartridge has either not been installed or not properly set. return for another one
Apr 24, 2009 | Brother DCP-7030 Digital All-in-One Laser...
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Lands Phones Logo
19 people viewed this question
Top Nokia Lands Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
