Question about Sanyo DP26649 26 in. TV
Can't set up, won't move from picture mode - Sanyo DP26649 26 in. TV
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
I can't get the color right. What are the perfect setting?
Hello!
Have you tried preset picture modes off TV's "picture" menu or "picture" on remote control unit. Most modern sets have "preset" modes: normal, vivid, natural, movie, sports, user, etc. Try to toggle between those modes. may be the one of those will look right for you. Make sure: "user" mode is for custo adjustments. You must choose desired settings: "picture(contrast)", "brightness", "color", "tint", "sharpness", "color temperature". May also have: DNR(dynamic noise reduction", "black level expansion", etc. I'd try presets, first and make notice of those settings. If that is, still not right to you, you may be able to tweak "user" mode the way you like it, based on info from other modes. If that won't help, you may have an issue with your TV.
good luck,
thanks,
Alex.
Sep 13, 2011 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
42" television that won't display
You have the picture mode set ion 4:3 if its not the TV it will be any cable or satellite you have connected, you need 12:9
May 15, 2011 | LG Televison & Video
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Nightscene + Portrait Suitable for taking photos of your subject in the evening or at night. This setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture. Landscape + Portrait Suitable for taking photos of both your subject and the landscape. This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is locked to wide-angle and cannot be changed. Indoor Optimum settings for taking pictures of family gatherings and groups of friends. This mode reproduces the background clearly capturing the atmosphere. Beach Suitable for taking photos at the beach under a bright blue sky. Colors of the sky, the beach and people are reproduced vividly. Snow Optimun settings for taking pictures where backgrounds are snow fields. Settings are similar to Beach settings and colors of the sky, the greenery and people are reproduced vividly. Fireworks Optimum settings for capturing fireworks in the night sky. Since this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture. Sunset Optimum settings for capturing pictures of the setting sun. This mode reproduces reds and yellows vibrantly. Again, this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Nightscene + Portrait Suitable for taking photos of your subject in the evening or at night. This setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture. Landscape + Portrait Suitable for taking photos of both your subject and the landscape This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is locked to wide-angle and cannot be changed. Indoor Optimum settings for taking pictures of family gatherings and groups of friends. This mode reproduces the background clearly capturing the atmosphere. Beach Suitable for taking photos at the beach under a bright blue sky. Colors of the sky, the beach and people are reproduced vividly. Snow Optimun settings for taking pictures where backgrounds are snow fields. Settings are similar to Beach settings and colors of the sky, the greenery and people are reproduced vividly. Fireworks Optimum settings for capturing fireworks in the night sky. Since this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture. Sunset Optimum settings for capturing pictures of the setting sun. This mode reproduces reds and yellows vibrantly. Again, this setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Sanyo DP26649 26 in. TV Logo
16 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
