Question about Hoover F5858-910 SteamVac Vacuum
Took it apart and cn't figure out where the little plastic square piece goes
2 Suggested Answers
SOURCE: HOOVER STEAM CLEANER PROBLEM
The switch in my hover steam cleaner is broken, how do I repair it
Posted on Feb 15, 2008
I took apart my eureka quick up vacuum and am not sure how to re assemble
I just did the same thing and had to reassemble also. I recommend turning it upside down. First make sure the belt is wrapped around the motor threads as well as the brush threads, then rest the brush more or less where it goes in the front of the vacuum. The white plastic pieces each have a small hole - you need to insert one end of the brush into each while plastic piece. When you lie the plastic piece flat you should see that the other end fits together with the top of the vacuum. The trickiest part is getting the tiny little wheels into place. Just worry about the 2 in front first. Set them carefully into place in the square holes in the front corners of the machine. Use your finger or a screwdriver to fit the mini axles properly into the grooves. Carefully push the bottom of the vacuum into place until it seems to snap in place (be careful that the wires are tucked in well) and screw in the 4 main screws. Final step is to reattach the smaller black cover to the bottom (back) side - be sure to get that wheel in place before fitting the cover on and then tighten up the final 2 screws.
Mar 25, 2011 | Eureka& Cordless Quick Up Vacuum
I took my Dyson DC 25 Animal apart to clean it, and now the red foot pedal won't lock the vacuum into the upright position anymore. The trouble is the spring pin for the pedal popped out and I can't figure...
That spring thing goes where the pedal screws into the side. When 'facing' the dyson in the front, it's on the left side. The spring's circle part and short stem section goes into a divot area on the pedal. The other end is tensioned (braced) against some housing piece, but once you insert the spring part in the pedal end part, you should be able to figure it out from there.
This darned spring makes the pedal 'tensioned' to where it pops back up vs. flopping nonsensically.
Feb 09, 2011 | Dyson DC25 All Floors Bagless Upright...
Formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
Mar 27, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Nov 14, 2008 | Eureka 411A Upright Vacuum
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes will not spin -- broken part
Did deeper, I finally just fixed mine today, I thought the same thing about it not wanting to come apart, but try one more time, and when your almost done, look underneath there is a long plastic piece with two screws almost side by side towards the front, take them out, remove the two rubber hoses on the top side and remove the turbine, opens real easy and clean it out, then wala it' work again...
Oct 16, 2008 | Hoover F7222-900 SteamVac Upright Vacuum
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
No spray
pump part number is 2107181, the diverter valve # 2136988. You can Bissell and they can tell you who may have parts near you, or you maybe able to order thru Bissell.com. Before you took it apart, were you getting water to spray out of the hose. If you were the the heater is plugged and won't allow water to spray out the bottom.
Feb 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Roller problem
I have 3 Prontos, one in each part of the house. Two of mine had the rollers stop. I figured out the problem and it fixed both. Take the roller out by turning the plastic screw and popping the plate off. Pull all debris off the wheel that turns. Turn unit on and make sure this wheel is turning freely. Take the brush and look on the end with the square part. Take some pliers and gently pull this square piece off. I had to wiggle it a little, but it pops right off. Clean all debis (mine had several small dust balls and 1 long hair) in the square part and down in where the square part goes. Push the square part back on and put brush back in unit. This fixed both of mine. Hope it helps.
Dec 18, 2007 | Electrolux EL1000A2 Pronto Bagless Stick...
Hoover F5858-910 SteamVac Vacuum Logo
14 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
