Question about Kohler Electrical Supplies
Kohler 22.5 command will not start - Kohler Electrical Supplies
2 Suggested Answers
  • 905 Answers
SOURCE: Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
Posted on Jun 12, 2010
How do I check for a blown head gasket
Dwayne, the third link talks about the signs and test for leaking head gasket. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
blown head gasket on kohler command pro 25 horsepower
How to replace head gasket on Kohler command
Legacy Kohler engine leaky head gasket repair
May 01, 2016 | Kohler Command V-Twin Horizontal Engine...
I got a 50in cub cadet ZT came with a Briggs on it . I'm putting a 22 hp Kohler command motor on it. I need the specs for all the wiring from the Kolher command motor to the Cub Cadet
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
Jun 15, 2015 | Cub Cadet Garden
Why oil consumption on kohler command 20
Either badly seated oil rings or PVC valve is stuck open allowing oil to enter through carburetor.
Oct 20, 2014 | Kohler Command OHV Horizontal Engine with...
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
May 30, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical Supplies Logo
12 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
