Question about LG Office Equipment & Supplies
Lg projector Black and white vertical line appeared on the screen
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
If it is intermittent, make sure it is not over heating and that it is clean on the inside.
Posted on Jul 03, 2015
Marrie
  • 563 Answers
SOURCE: White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
  • 74 Answers
SOURCE: projector has vertical white lines
You have dirty contacts between the dmd board and the dmd chip, or the dmd chip is bad. If the dmd is bad you'll need a new light engine.
Posted on Sep 19, 2009
SOURCE: Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Posted on Oct 16, 2009
projdoc
  • 2237 Answers
SOURCE: Projector has vertical black lines going through
if they are thick and shadowy, the light tunnel is collapsing. if they are thin and defined, check the resolution. reset the settings to factory default.
Posted on Nov 10, 2009
Black and white vertical lines
Make sure the unit is not full of dust.... when it gets hot the video goes screwy...
Apr 18, 2014 | LG Office Equipment & Supplies
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Vertical black lines. But they are not solid. lg plasma 42pc3dv
This could be a poor connection with the LVDS cable which runs from the main video processing board to the screen, or a fault within the video processor on the main board. Worst case scenario is it could be a fault with the screen itself.
Jan 08, 2010 | LG 42PC3DV 42 in. Plasma EDTV
A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
Oct 02, 2009 | LG RD-JT91 Multimedia Projector
Nov 25, 2008 | Office Equipment & Supplies
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
158 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
scj103
Jaime Hernandez
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
