Question about Makita G1300R Portable Generator
Makita G1300R no power
No 115vac out to the plug
Can i bypass the switch on a makita skill saw
OMG, absolutely NOT!
I know a guy without 3 fingers due to one of those on a construction site. He said he never felt a thing.
Buy a new switch.
  • Makita Canada Inc. www.makita.ca Makita Canada: The best in class for cordless power tool technology. A leader in power tool technology for the professional.
  • Makita Saw Parts ' Great Selection ' Great Prices ... www.ereplacementparts.com/makita-saw-parts-c-97_98.html Fix your Makita Saw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
  • images of makita saw parts bing.com/images th?id=oip.m79ac54922c7af758ce5909fe9cde9163o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m8226e4e7540d1403e6b34f0609fee8ado0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mc9c1b6c779ab4de644cda35842865ffbo0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mfb5ac75b7411568957f4d7028521f0b4o0&w=80&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdd935730eb9fe8614bf23952794b8ca9o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.md1140885e7ec8b5124cabfe71fdb3085o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of makita saw parts
  • Makita Power Tool Parts - Makita Parts - eReplacementParts www.ereplacementparts.com/makita-parts-c-97.html We have the genuine Makita parts and tool repair help you need to get your power tools running like new again.
  • Makita Parts - Tool Replacement Parts ' Tool Parts Direct www.toolpartsdirect.com > Brands Makita Tool Parts - Shop Makita parts online at Tool Parts Direct. Over 38,000 Makita replacement parts and schematics available.
  • Related searches for makita saw parts
  • Makita Tool Parts :: Makita Saws - Tool Parts Canada ... www.toolpartscanada.com/makita-tool-parts/makita-saws-page-3.html Please choose your tool from Makita Benchtop line below view parts breakdown
  • Makita Saw Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Makita Parts Shop the best selection of Makita saws repair parts and accessories at Sears PartsDirect. Find replacement parts for any Makita saws repair project.
  • Makita - Authorized Factory Service Centers www.makitatools.com/en-us/Modules/Service/ServiceCenters.aspx Makita Authorized Service Centers meet our high-quality ... Genuine quality Makita replacement parts; Most tools repaired within 3 days; Maximum Repair Cost Program;
  • Makita Saw Parts ' eBay 9k= www.ebay.com/bhp/makita-saw-parts Find great deals on eBay for Makita Saw Parts in Corded Circular Saws. Shop with confidence.
  • PARTS - Makita UK https://www.makitauk.com/shop/parts Parts . Ask Makita ' Find a dealer. Part search Search for tool drawing: Filter: 1 - 2 - 3 - 4 ... Contact Makita! 01908 211678. Monday - Friday 8am to 5:30pm.
  • Makita Tool Parts - Tool Parts Canada - Parts that makes ... www.toolpartscanada.com/makita-tool-parts.html Please Choose Makita category Below Which Matches Your Tool
  • Jun 20, 2016 | Makita Saws
    Have had generator in storage, Makita G1300R. What do I need to do repair wise to get it to start after about ten years in storage??
    Remove air filter assembly. Disconnect fuel line from carburetor and drain old fuel into suitable container to discard. Fuel Shut Off in the On position. If fuel has gelled up in the tank or lines, add small amount fresh fuel in fuel tank, swish around several times and flush until clean.
    Loosen and remove Carb Mounting nuts, throttle linkage and spring (note the position). Carefully remove Carburetor and very carefully remove gaskets (do not discard until completion of final reassembly)
    Disassemble Carburetor and thoroughly clean with appropriate cleaner and immediately following with compressed air. If thick gelled old fuel is present, soak disassembled carb in cleaner overnight before using compressed air is highly recommended.Reassemble carburetor, replace gaskets and install Carburetor (Reverse dis assembly) Inspect and replace air filter upon reassembly.
    Inspect spark plug and replace (do not over tighten).
    Add fresh fuel and perform start procedure. Initial start might take a few pulls but should start right up.
    Sep 23, 2014 | Garden
    I have a 1 horsepower variable speed blower motor for a Ruud furnace with plug-in power source and plug-in low voltage signal input plugs. I can't find the capacitor and want to know if I can direct-wire...
    No you cant. You have a module motor so there is no capacitor. If the motor is new it may not be programmed. If it is a old motor replace it.
    Sep 07, 2014 | Heating & Cooling
    TV Goes Dim
    Check the power coming into the TV socket with a multimeter...should be around 115Vac or more. Try plugging in the TV to a different outlet in another room....maybe a bad socket!
    Dec 26, 2012 | LG 32LG30 32 in. LCD HDTV
    PROfORM xp TREADMILL TURNS ON BUT BELT DOES NOT RUN
    CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1) faulty speed sensor OR need to readjust do it the face must be face to face with the magnet from motor 2) the speed sensor is not plugged in properly 3) also faulty motor Test for 115 VAC coming from the main motor board 4) control board or lower board.faulty Testing from incoming input from transformer for 115VAC + 5VDC 5) Test the main transformer for input 115VAC, and secondary for power supply +5VDC 6) See if the power supply has output for +5VDC 7) See if there are some component from power supply : resistor+ capacitor+diode or IC.burning. 8) Lubricate your Deck belt very well. See finally the schematic diagaram supplied for me, and see the diagnostic for best troubleshooting.
    Sincerely. Mery Christmas.
    erensto cuadra
    managua, nicaragua
    Dec 18, 2011 | Proform XP 590S TREADMILL Drive Motor
    Have a makita gas cut-off saw dpc7321,has spark to the plug but will not start,it is getting plenty of gas too
    Is the gas fresh? Is the plug wet with fuel after you try and start it? Have you done a compression test on the engine?
    Jul 09, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
    I have been told that the vx510 card processor can be run off of a UPS for occasions when AC power isn't available. I cannot find power consumption figures on the vx510 excep for a voltage rating of...
    The vx510 operates with a power adapter. The 115VAC is what the adapter plugs into, and the DC numbers are for the output to the actual machine. Basically you just plug the power adapter into the UPS and it's already plugged into the machine...just like a laptop, etc.
    However...the figures your are quoting of 22-26VDC at 1.5 amps do not agree with Verifone's published specs for the vx510 of 9.4 VDC at 4.0 amps (link to product specs page). I'd be very careful.
    Hope that's helpful.
    Jan 06, 2011 | Computers & Internet
    Not working after wrong settings
    If your main power is 220Vac and it is set in 115Vac. It could be you actually fried your power supply.
    Here is the reason, in common power supply after the rectifier diode when it is set in 115Vac, its circuit acts as a voltage doubler, its mean in its downsteams it actually uses around 220Vdc. And when you uses it in 220Vac it will connect directly as a rectifier.
    When you set it in 115Vac and plug in 220Vac. In its downstream it could be in 440Vdc, then its an overvoltage everything that can't compensate will be damaged.
    Hope I give you some info.
    May 31, 2009 | Vantec iON 2 VAN-460N (VAN460N) 460-Watt...
    Makita Generator no power
    Hi Laurence,
    Hope you had as good a holiday as I did :-)
    Yes the squareish thing in there is a kind of voltage regulator. More correctly, your brushless generator is using this capacitor to regulate output voltage by means of a resonant circuit between a winding on the stator and this part. The short answer is that you more than likely need a new one and because of its particular shape the only realistic source of the new one is Makita.
    I disagree with the service tech about the testability of the thing, my Fluke 112 DMM has a capacitance function that would let me tell if your capacitor was shorted ( 0 mfd reading), open (infinate mfd reading), or some value that could be compared to whatever "known" one was applicable. In this case I'd take a loose guess that the reading of a good one is something like 20 - 100 mfd, but that's just a guess.
    let me know if the new capacitor doesn't get it,
    Carl
    Dec 31, 2008 | Coleman Powermate Powermate 5000W...
    Makita G1300R Portable Generator Logo
    Top Makita Electrical Supplies Experts
    obsteiner
    Tom Chichester
    Ogbonna promise
    Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
