Question about Toys
Where is data link connector on 2009 peterbilt 387
  • 333 Answers
SOURCE: i cant find the data link connector
its in the center console. pull out the ash tray and its right under it
Posted on Jan 16, 2009
  • 11 Answers
SOURCE: locating the data link connector
try this
Posted on Jan 29, 2009
  • 1274 Answers
SOURCE: want to know how to prevent feed back in my cb
Hi kyle,
Welcome to FixYa.
My name is John. I will be assisting you with you issue. The first thing you can do is reposition it in a different location, away from speakers, wires, am antenna coax,etc.
If you have more issues, let me know.
Thanks for using FixYa. Happy Holidays......John
Posted on Dec 27, 2010
  • 130 Answers
SOURCE: why would a data link connector stop working
Has it ever worked? Possibility no positive supply or ground at data link connector. Need to locate a wiring diagram for your connector. Try google.if you don't have a diagram.
Posted on Jul 07, 2012
obriensauto4
  • 5 Answers
SOURCE: where is the data link connector on a 1992 honda accord
behind right side of dash , above kick panel
Posted on Aug 31, 2012
2009 peterbilt 387, hard to steer when start driving in the mornings & parking. Once on the road she loosen up and drives fine. What's the problem?
Could be low on power steering fluid?
Even the electro-hydraulic pas systems use fluid.
If it isn't that, the problem should be investigated in case it is safety related. It could be a tight track rod end or steering swivel ball joint or a semi-seized strut swivel bearing. If rectification isn't carried out component failure could be the eventual result with the possibility of some very exciting consequences as a piece either breaks or falls off...
May 13, 2016 | Cars & Trucks
2010 peterbilt 387. Why doesn't heat come out?
check that the heater control tap is being turned on when you select hot
check for air trapped in the heater core and not allowing hot water to circulate
Oct 05, 2015 | Cars & Trucks
2015 Peterbilt 387. Why doesn't the heater work?
It's so new you should not have a problem but you are not getting coolant to flow through your heater core. I suspect an electrical problem around the water shutoff valve or a vacuum hose or cable not opening the heater valve. You might be able to manually open the heater valve.
Can't find fuse for cb radio on a 2006 387 peterbilt
if you are going to hook it up directly because its your truck then you need to find the fuse panel. In there should be the fuse or circuit breaker you need.there should also be two connectors on your dash,one pos and the other neg. then there is the trusty old cigarette light plug.those are your options.
May 02, 2014 | Radio Communications
02 peterbilt 387
Sounds like the relay is getting overloaded. Are the lights aftermarket extra brights? The likely cheapest "fix" is a new relay, but if you put a higher amperage one in, the wiring might get melted.
Jan 25, 2014 | Vehicle Parts & Accessories
Where is the abs located on a 2001 387 peterbilt
on any car/truck it is going to be near the brake master cylinder, so follow the brake lines from there.
carprog full v4.01
Mar 04, 2013 | Cars & Trucks
Toys Logo
35 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
