Question about Spectroniq PLTV3250 32 in. LCD TV
Tv jumps randomley between different inputs HDMI, component, ect
The problen started a week after getting the tv and continuse to get worse so as now it jmps continually to differnent input sources HDMI ,component analog . Never could get any help from the company or shop NBC. Is this a part that can be replaced. The time starts out slow but wets worse as the tv warms up. It is not the remote control it happens even with the battery out of that. Is this switching mechanism available? Or is there a work aound I would be happy with just 1 HDMI input.
  • 4,234 Answers
With a set that new, you should be able to return it for warranty exchange or at least warranty service. The internal logic is having a problem, the power module is not up to the task, or there are just simply a few defective parts inside. In any case, there is no reason for you to worry about this, this is the type of thing that is covered by warranty.
Try that first.
Keep us posted,
Dan
Posted on Jun 19, 2009
How to get tv back on. was trying to adjust picture size and accidentally clicked something to do with the HDMI and now tv won't come on
Hi U might have put youre TV into sleep mode ... unplug power cord for a few minutes if it is the problem it should lose its memory.,.good luck
Sep 02, 2016 | Televison & Video
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
RCA R2WH74YX58 tint problem
Your green CRT may be going bad, You can get a replacement CRT ( picture Tube) at the following link very cheaply with free instalation instructions.
Sep 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hdmi input not working
Video is different from HDMI. From what I have seen you should have video inputs and component inputs. instead of trying these video inputs, look for tv/component button on your remote or tv settings.
Feb 01, 2014 | Toshiba Regza 52XV645U LCD TV
How do I connect my PS2 to my Alba flatscreen TV? I plugged it in and everything but I go through all the channels and AVs (HDMI, HDMI2, Ex-1 ect) but I can't seem to find the channel that the PS2 has...
select the channel that corresponds with the way you connected it if it is component video check those inputs otherwise it could be an hdmi input. if you have it hooked up and you know for sure you have checked the input that corresponds than you most likely have a bad cable try a different cable to hook it up
May 09, 2011 | Video Game Consoles & Games
Tx-sr606. Signal lost to TV on HDMI Out. Coming in from Component Video or DVD or Game Components. Audio is playing but I get no signal to TV. HDMI Cable is fine. usually have to turn it off or unplug...
Check the most popular solutions.Also check that if you give the receiver some time (in my situation at this moment about 10 minutes) after you turned it on an selection of source.
I just received the new capacitors from a German store and will install them 2 weeks from now.
Rgrds,
Phil
Jan 25, 2011 | Onkyo TX-SR606 Receiver
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Single HDMI Input. Need to connect several HDMI components
Number 1 would be to connect the 3 Devices to a Receiver with 3 HDMI Inputs, So this way you get the HDMI Audio as well. 3 in and 1 out to the TV as you know. The other way would be to get a Key Digital HDMI 3 to 1 Switcher. I have used these a lot in the field on installs and they work Great. They also have 4 to 1 if you think you might need more. No programming of the piece you just plug in and setup your TV in the HDMI Menu and your other Devices. If they don't sync AUTO! The Receiver would be Best I feel, Some let you assign 2 different Video and Audio sources at once. Such as Video from a Game and Audio from a CD. Hope this helps out!
Apr 20, 2009 | Mitsubishi WD-73833 73" HDTV
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
Spectroniq PLTV3250 32 in. LCD TV Logo
180 people viewed this question
Top Spectroniq Televison & Video Experts
Chinmay Joshi
Chinmay Joshi
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
