Question about Sabre Televison & Video
I have a Dell M1730 XPS laptop. I am trying to connect the DVI cable to a Sabre 36" television using a DVI to HDMI adapter. It does not work. Can the Sabre TV resolution be adjusted to solve this problem?
    Scholar:
  • 174 Answers
That means your problem is in the connecting wire. Sabre TV resolution is auto-adjusted once you connect to the laptop.
Please check the external connections first.
for more info: you can follow:
http://www.netlobo.com/laptop_tv.html (technicalities)
http://www.sabrevision.com/gdslcd.htm (for manuals)
gud luck.
saumya.
Posted on Jun 19, 2009
Both fans stopped
Hi
make sure the funs are working in another machine or using a battery if it works the problem is the motherboard.
May 05, 2014 | Dell XPS M1730 Laptop Power AC Adapter /...
How do I set my Dell laptop to Samsung TV using HDMI
If you have a HDMI output on your laptop, then you should be able to plug a HDMI cable into a HDMI input on your T.V then change your input source on the t.v. If you don't have a HDMI output on your laptop then you should be able to use a DVI cable as long as your t.v has a DVI input, they also make a DVI to HDMI adapters, but keep in mind that DVI cables/adapters do not support audio.
Jun 25, 2011 | Samsung Televison & Video
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
Cant get hdmi to work
What device are you connecting to the TV? Are you using an HDMI to HDMI cable or a DVI to HDMI cable (or another adapter in the cable or between the cables)?
Try using a different cable. Try connecting the source device to another TV. Basically, you want to see whether the TV's HDMI input is bad, the device output is not active, or if the cable is bad (or an adapter attached to the cable is bad). Adapters are likely failure points. If you are using a DVI to HDMI cable, check your cable and device specs. Single-link and dual-link DVI are different and not interchangeable when attached to an HDMI cable end.
I hope this helps.
(some computers (esp. laptops) will have external video ports turned off by default and you need to turn them on before you try to send the output to an external monitor (TV).)
Apr 17, 2010 | Televison & Video
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Power issues
Dell laptops use proprietary power supply adapters. Inside the adapter there is a communication device telling the laptop the power supply is a genuine dell product. Which in turn allows the battery to charge. Anyways it appears that your charger is having problems. You should probably try to locate one local (from friend or computer repair shop) to test. if you try a good one with no problems, then just get on Ebay and get you a genuine dell charger. they are about 40-60 dollars. Or try calling dell.
If trying a known good charger doesn't correct the issue, you could have broken solder pins on the power jack inside the laptop.
If this helps you solve you issue please rate my solution.
May 05, 2009 | Dell XPS M1730 Laptop
Where to fit a hdmi cable
The aspire 5520 doesn't have an hdmi port but does have a DVI connector on the left hand side slightly forward of the VGA connector. If you are trying to connect the laptop to the hdmi port on a television you'll need a special cable or adapter. Adapters and cables are readily available to convert DVI to hdmi.
Dec 16, 2008 | Recoton Advent Advent Q2035A 20" TV
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Televison & Video Logo
29 people viewed this question
Top Sabre Televison & Video Experts
Tom Chichester
Are you a Sabre Televison and Video Expert? Answer questions, earn points and help others
