Question about Fantom Drives G-Force (GF500EU) 500 GB USB 2.0 Hard Drive
Not recognized just reinstalled windows XP home edition now it does not show the external g force 500 hard drive, at the bottom it says device can run faster with usb 2.0 Please help I have alot of files stored on it I need
    Problem Solver:
  • 7 Answers
This may not be the external hard drive issue. Check your USB driver, under device manager. You might need to upgrade the driver. If you plug your external to another computer, you will see that is it working ok. Just re-installing XP might have not installed USB drive properly.
Posted on Jun 19, 2009
How to make my 500 mybook compatible with windows vista
Normally by default, these external storage devices are pre-configured to work with Windows XP, Windows Vista, and Windows 7. If you are having troubles making it work with Windows Vista, try to reformat the device with NTFS formatting and it should run smoothly.
Cheers!
Apr 08, 2011 | Western Digital 500GB My Book World...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
My pc now recognizes the drive as a local drive, but the drive cannot be read. Is it possible to restore the drive without deleting the files on it? They are some extremely important.
There are several things to try:
1) Disconnect all USB devices and restart the computer. Then plug in your external Hard Drive. In some cases, this has worked to enable external devices as there's a conflict between some USB devices. Once working, you can add any other USB devices you have.
2) Since the drive is recognized by XP, right click on it and if you have access to Tools, try to check the volume for errors. It may ask you to reboot and do a scan disk on startup. Sometimes although the computer recognizes the volume, it hasn't sufficient information as to how to access it. Running a scan disk can cure that problem.
3)Re-assign the drive letter; Occasionally XP can't access a path to the external drive; if it assigns a letter, in turn it will gain access
Change Drive Letter
The link above provides step by step instructions to change the drive letter
4) Run Windows Update and install SP3; Service Pack 3 addresses issues with external devices that weren't fixed in either SP1 or SP2
I do hope one of these answers provides a solution to your problem. Please post back with any other questions or just to let me know how you made out. Unfortunately, you have a common problem but no one FIX has been identified by Windows to solve it.
Best of luck!
Greg
Nov 06, 2009 | Western Digital My Book Essential Edition...
Computer will not recognize one 500 external hard drive- nothing wrong with connections- other external hard drives are fine. I have tried everything
What OS are u working on? some old ones dont recognize this big hard drives, cant remmember the limit but it was around 300. Try updating ur OS if u are working on windows xp(get it to Service pack 3). I think this problem was fixed at sp2, but just to be sure.
Nov 02, 2009 | Western Digital 500GB My Book World...
External Sata Drive no longer recognized
My friend it sounds like your hard drive. I know thats not what you want to hear. But don't worry there is hope! You can have the data retrieved from your hard drive by using this online company which I highly recommend:
http://www.gillware.com/
Aug 10, 2009 | Western Digital My Book Home Edition 500...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
Computer not showing external hard drive
Try the following : -
(1) Connect to any other Computer and Run Disk Clean-Up Wizard under Tools from Windows Maintenance.
(2) Now, connect your Hard Drive to your Computer and will be detected.
Jul 01, 2008 | Western Digital 500GB My Book World...
External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
May 12, 2008 | Western Digital My Book Essential Edition...
Fantom Drives G-Force (GF500EU) 500 GB USB 2.0 Hard Drive Logo
193 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Computer Links
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
