Question about Garden
What preasure on the gauge - Garden
How to take a oil pressure guage off a 2002 jeep cherokee
not guage, it gauge.
take out a spark plug. put the gauge end in spot & crank eng. Read the gauge.
Jun 07, 2012 | OMC High Preasure Oil Line P32-47516-13
Oil pressure drops to zero at idle on 2002 GMC Envoy after engine warms up
You could have three possable problems that I can think of. 1) Your oil viscosity is too low and you need to change it to a higher level. A 5w/30 or 10w/30 oil may thin out too much when it warms up to normal temp and shows low on your gauge. 2) The preasure relief valve is partially open due to a small piece of debris caught under the seat. Unscrew the oil filter and look at the small disk that is near the threded part on the filter base. Theres a spring behind it to keep it closed so all the oil goes into the engine and not bypass back into the oil pan. Push up on it slightly with a small tip screw driver and see that it fully seats in the hole, put a new filter on, and try it. 3) If these two things don't improve the condition, get a socket for taking the oil preasure sender off and get a oil preasure gauge to test the actual oil preasure the engine is producing. You may have a weak pump in the engine. If the preasure is within good specs, I'd change the sender unit with a new one.
Let me know what happened-
Craig
Jan 18, 2011 | 2002 GMC Envoy
Loose oil pressure when you let off of the gas on a 1998 chevy tahoe need to know if i can change the camshaft bearing with the motor still in the truck i put in new oilpump rods and main bearings in...
you can but will need to remove radiator and a/c condensor and maybe grill, you need room to slide it out and to use the tool to remove the bearings,also if you are replacing the bearings i would highly recommend replacing the camshaft,also did you replace the oil preasure switch or test the oil preasure with a gauge to make sure you were loosing preasure, or did you do this by the inside gauge. hope this helps.
Sep 05, 2010 | 1998 Chevrolet Tahoe
Start up is rough idle and chokes on acceleration for about 4 to 8 miles then smooths out
sounds like dirt in fuel buy a good fuel cleaner and put it through the fuel system should solve the problem after some miles.adrian,,,,,,,
Aug 19, 2010 | Ford F-250 Cars & Trucks
When engine is cold ,i get a hard start
This can be caused by many things like a bad fuel pump not holding preasure or a bad coolant temp sensor giving a false reading or bad module. the best thing would be to have a scan tool hooked up and look at all the input and output readings to see if something is off, and also a fuel preasure gauge to watch the preasure. this is going to need a shop otherwise youll be geussing and thats expensive, sorry i couldnt help too much.
Aug 06, 2010 | 2005 Mazda 3
My runs fine for a little while then starts to spit and sputter like it is starving for fuel.
Hook a fuel preasure gauge to it and run it until it acts up then check the preasure, if the preasure goes low ,replace the fuelpump.
Jun 09, 2010 | 1993 Jeep Wrangler
How do I reset the low tire gauge on 2007 passat?
pump tyres to correct preasure. press and hold the tyre preasure button for a few seconds (I think the button is near the ashtray)
Feb 21, 2010 | 2002 Volkswagen Passat
Low oil pressure light is on on 2000 lexus rx300. Doesn't need oil or an oil change. Not leaking oil.
try replacing the oil preasure switch, if that doesnt solve your problem then have your oil preasure tested, if it really doesnt have oil preasure it will cause internal engine damage so start with the switch and then go from there, hope this is helpful.
Nov 29, 2009 | 2000 Lexus RX 300
2002 GMC Sierre Crewcab 4x4 Duramax Diesel A/C problem on 2003 duramax, air blower blows but air is not always cold. Often starts blowing cold air but the air gets gradually warmer as if AC is not on. I...
ok now you said,the system was checked to be sure the refrigerant level was full . It could also be over full causing a over preasure shutdown. The compressor has a low and high pressure switch, that will disengage the compressor clutch if it senses a over or under preasure situation to protect the system.Did you check to see if the compressor clutch was Engaging and will it stay Engaged or disengage and keep cycling like that? you Will need to get the preasures on the high and low side of the compressor from a gauge manafold set and please record the outside temp. it will change the preasures in the a/c system than i can better help with the issue you have. also a/c will always work better if recirculated air is used, because it is already cooler than out side super heated air.
my name is ron and if you get the preasures for me i will be glad to check the preasures to My R-134 refrence card
Jul 31, 2009 | Heating & Cooling
My oil preasure gage will show normal when the truck is sitting idle. as soon as i give it gas there is no preasure at all. . It has also been trying to over heat
Doesn't sound good. Your oil pump may be going out that would explain over heating and eventually disaster will strike. You need to install a external gauge and verify that at least you gauge in your vehicle is reading correctly or have someone do it for you. Shouldn't cost much over $60 for private repairmen to do this that would at least tell you that it isn't a gauge issue but I would bet money that your oil pump is weak.
Jul 29, 2009 | 1995 Ford F150 Styleside Regular Cab
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
