Question about Boating
Benjamin pump air rifle repair
Bolt doesn't close
  • 88 Answers
SOURCE: Benjamin Air Rifle Model 342 not building pump pressure
Springs tend to loose their performance after a few years is air rifles. Check also the seal/o rings on the piston rod and the blow hole. I found waxing it with Vaseline makes it last longer and seals more.
Posted on Aug 29, 2009
SOURCE: I need a parts diagram for a benjamin sheridan
you can find parts diagram in crossman web page under other help compleat dig with part#s
Posted on Oct 14, 2009
agent91
  • 2100 Answers
SOURCE: need parts for a benjamin franklin air rifle moel
http://www.crosman.com/airguns/service/repair
I couldn't find the model 317, But crosman bought benjamin, sheridan. Check it out.
Posted on Feb 24, 2010
  • 13 Answers
SOURCE: Benjamin Marauder air rifle is leaking air ????
I presume you've solved this problem by now. But for future reference, the Marauder "Owner's Manual" explains why this may happen, and how to solve this problem!
"TIP: If your airgun is being filled from completely empty (zero pressure) the tension of the hammer pressing against the valve may keep the valve open which will cause air to leak down the barrel. This is most likely to happen with a gun tuned for a high fill pressures, where the hammer spring preload is adjusted to a high rate. In the event this occurs try cocking the bolt and leaving it in the rear (fully open) position to eliminate
the force on the valve allowing it to close. Always make certain the airgun is not loaded and there is not a pellet in the chamber."
Posted on Oct 09, 2010
19ken55
  • 426 Answers
SOURCE: Benjamin 392 air rifle leaks
Put oil in barrel in chamber and clean out dirt with compressed air.
BE CAREFUL
Posted on Feb 01, 2011
I was told there was no such thing as Benjamin Franklin mod 312 Ser h322837 but is in enshrined on the barrel, I need to know
Definitely exists and looks collectible.
  • Benjamin Franklin 312 .22 ' Gun Values Board www.gunvaluesboard.com/benjamin-franklin-312-.22-2923214.html My father has a Benjamin Franklin , model 312 .22 cal. Lever pump rifle , ... A Benjamin 22cal air rifle with a ser ... .22 cal Mod. 312, ...
  • i have a benjamin franklin 312 air rifle with no serial ... https://answers.yahoo.com/question/index?qid=20110411133733AAHQmgM
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2011-04-11 · I have a benjamin franklin 312 air rifle with no serial numbers on ... What you have is a Benjamin model 312, ... I have a benjamin franklin 312 air ...
  • Advice on what to do with Benjamin 312? - Airguns & Guns ... www.gatewaytoairguns.org/GTA/index.php?topic=25607.0 Advice on what to do with Benjamin 312?, ... Benjamin Pump mod. 397 ... SE CT; Beeman C1 .177 Daisy 230 (Milbro)
  • Related searches for Benjamin Franklin mod 312 Ser h322837
  • I Have A Benjamin Franklin Model #312 - Lever Pump Air ... www.gunvaluesboard.com/i-have-a-benjamin-franklin-model-312...rifle... I have a Benjamin Franklin Model #312 - lever pump air rifle in .22 cal. The stock is broken & I would like to get it fixed. ... A Benjamin 22cal air rifle with a ser ...
  • Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle ... www.ebay.com/sch/sis.html?_nkw=Benjamin+Franklin+Brass+Mod+312+22... Find best value and selection for your Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle Gun For Parts search on ... Benjamin Franklin Air Rifle for parts . $ ...
  • Item:8679966 Benjamin Franklin 312 AIR RIFLE PARTS .22 For ... classic.gunauction.com/search/displayitem.cfm?itemnum=8679966 Seller's Description: Benjamin Franklin 312 AIR RIFLE PARTS .22 Nice old Benjamin 312 barrel, receiver and stock Pumps air okay but there is no way to release it as ...
  • benjamin franklin 312 - Airguns & Guns Forum www.gatewaytoairguns.org/GTA/index.php?topic=37115.0 benjamin franklin 312, Air guns, Airgun Forum ... 2 RWS mod. 48s, 177, & 22 2 Benjamin Marauders 22, & 25 Benjamin Trail NPXL1100 Benjamin Pump mod. 397, ...
  • Benjamin 312 strip, tear down & dis-assembly - YouTube www.youtube.com/watch?v=W1_DGNaaAs0
    • BY NORTHWESTAIRGUN
    • 17 MIN
    • 45K VIEWS
    2014-02-06 · Video embedded · Video of the dis-assembly of the Benjamin, or Benjamin Franklin, model 312. This is similar to the model 310, 317, 342, 347, and ...
  • Ben franklin air rifle mod 312 parts diagram - fnsxowf.gq fnsxowf.gq/zeuimpooku I have come across a Benjamin Franklin Mod.340 Cal.Buy Benjamin & Sheridan ... Benjamin Franklin 312 Pump air rifle.New airguns and vintage are available in our ...
  • Need A Repair Kit For A Benjamin Air Rifle Model 312 ' Gun ... www.gunvaluesboard.com/need-a-repair-kit-for-a-benjamin-air-rifle... need a repair kit for a benjamin air rifle model 312 ... I bought an old Benjamin air rifle model # 312. ... I have a Benjamin Franklin Model #312 ...
  • What is my Benjamin Franklin model 312 cal 22 h148881 man in USA
    May 20, 2016 | Optics
    Discovery Dual Fuel Air Rifle .22 PCP 900fps- Pump Included
    These are made by Crosman Firearms - call their help line 1-800-724-7486 - they will talk you through diagnosis or identify an authorized repair station in your area.
    Nov 14, 2013 | Benjamin Discovery Dual Fuel Air Rifle .22...
    Benjamin 392 air rifle leaks air out of the end of the barrell as pumping it up
    BE CAREFUL
    Feb 01, 2011 | Dmm Benjamin Air Rifle
    How do i change my benjamin air rifle pump seal?
    pyramidair.com has a seal kit. it also comes with a diagram. Benjamin and Sheridan air rifles do not have springs to propel the pellet. also never use vasalin. specifically for a Benjamin or Sheridan you need to use pelgun oil (also found at pyramideair.com). use pelgun oil because it is a non detergent fossil compound) the main intention is to condition the seals every 250 rounds. never use silicon based lube for this gun specifically. silicone lube is for spring air rifles such as break barrels.
    Nov 23, 2010 | Dmm Benjamin Air Rifle
    Benjamin Marauder air rifle is leaking air ???? does not hold pressure
    If a drop of oil in there won't swell up the seal, you will have to send it back to Crosman. They bought all Benjamin/ Sheridan services, they repair the rifles fairly cheap. You cannot take this apart, If you do, you will be sending them the pieces anyway. They have giant presses and jigs for holding the springs. I have had a bunch of rifles sent there. Check it out.
    Aug 18, 2010 | Dmm Benjamin Air Rifle
    Need parts for a benjamin franklin air rifle moel number 317 177cal
    Feb 22, 2010 | Dmm Benjamin Air Rifle
    Mar 27, 2009 | Dmm Benjamin Air Rifle
    Model 342 Benjamin Franklin 22 caliber air gun
    I recently purchased a rebuild kit for my 342. I bought the kit from airgundepot. It was the kit for the
    392 and I modified it a little. On the new plunger, you have to drill a hole in the center of it the same
    size as the pin's smallest diameter. You can use all of the parts in this kit except for the small o-ring. I think it sold for about 39 dollars or so. My rifle was manufactured in 1972 and it fires like new.
    Jun 03, 2008 | Crosman (4032)
    Boating Logo
    37 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
