SOURCE: I have a lawn mower that needs a spark plug. I
reason for different plugs are because motors require different lengths ,temperature,design etc-it may run now but if its to long-or short can cause engine problem or damage-same for hot or cold can burn valves-or carbon up valves or plug -change it to the recommended plug mower will last longer with correct replacement parts
SOURCE: lawn mower has too much oil. how do I drain excess
Remove the small plastic oil filler plug where you put the oil in, and turn the lawnmower onto it's side to drain any or all of the oil.
SOURCE: Can I download an instruction manual for the
go to this free manual site,no crappy ads just asks for 1 answer when you download a manual. it is a great resource
http://www.manualsonline.com/
SOURCE: I have a problem with
if you have your make and model number, you can order this online at www.mtd.com, or any lawn mower shop would carrie it.
