Question about Sony Ericsson K320i Cellular Phone
Some of the buttons dont work after prolonged usage.
Some of the buttons do not function after prolonged usage. If you give a long break the buttons gets activated by themselves. i am not able to understand this. Pleeeaaassseee help.
  • 244 Answers
Re: some of the buttons dont work after prolonged usage.
Replace a new one button pad of your phone.
Please rate me solve if you like my solution.
Best regards,
Posted on Nov 02, 2007
0 characters
3 Points
Lg F6 wifi button in settings is faded and wont let me turn it on/off and it used to work fine and i dont know if i did something or wat. Any ideas on how to fix it?
Have you tried turning your phone completely off for ten minutes than turning it back on , this used to work with mine, also check your data usage. Sometimes when I used too much data this would happen. A clean screen can help too. Cheers
Apr 25, 2015 | LG Cell Phones
How to make your nokia phones work smooth and fast and keep it maintained.
The usage of the phone memoy in nokia phones is the main reason for slow functioning and hanging. So always keep 80% of the internal memory free or smooth functioning of the phone. For data one can use a memory card.
If the phone memory is mostly used or full transfer the files or delete it.
the only problem for freeing space in symbian phones is it needs to be formatted because it has many hidden files of the installed applications in the phone memory. So you can format the phone by dialling *# 7370 # or by pressing the Switch on + * + 3 + call button when the phone is off.
on Jan 13, 2010 | Cell Phones
LG GW525 Battery Prolonging
hi , your phone usage will determine your battery life . turn your display brightness down to 3 or so. max charge time should be 2h30 min
Sep 29, 2013 | LG GW525 Cell Phone
The battery drains off very quickly as soon as i fully charge it and unplug it,, it hardly satys upto 12hours with minimal phone usage,, the battery metre usage shows cell standby 42% and also phone idle...
Go to teh phone settings, and under sync accounts disable all teh sync accounts that you are not using such as stocks etc. These constantly use up data and hence drains your battery as they do so in teh background. This should greatly improve your battery. If not, your battery must eb damaged and i woudl suggest you purchase an extended battery which may have up to 40% more battery life.
Jan 12, 2011 | HTC Wildfire Cell Phone
Running and working fine until next use there was no power. Bosch shu3032. Is there a fuse or reset that may have tripped?
The device is powered by extensive battery cells. It is requires rechrge depending on the duration of prolonged usage. Acquiring a new battery to replace the old one would be best alternative resolution. The battery area is located at back bottom area of device. It may need unscrewing to loosen for change purposes.
Jan 11, 2011 | Audiovox Bosch 718 World Cellular Phone
What is quota usage warning? im using karbonn k570 i get this warning as i switch on my mobile what to do
dont know if this is right place to post but anyways...
my cell phone when ever i switch it on gives a message "quota usage warning" with seconds countdown to 10. i generally click "ok" and it works alright.
due to which i am not able sms............
Jan 01, 2011 | Cell Phones
How do u reset the phone?
to reset your phone go to settings -> factory / default settings -> give your phone password ->ok
Apr 15, 2010 | Samsung Sway SCH-U650 Cell Phone
No, wifi is completely seperate from the cellular network. It will not cost you anything, but will depend on whether or not there are wireless routers/networks near you and if they are secured (with a password) or not. Wi-Fi is basically a home/office internet connection, just wireless.
For example, all starbucks has 'wi-fi'.
If you don't have a data plan for your phone, get a data block immediately from Bell. They dont like giving data blocks, and they say some functions wont work but they mean stuff that connects to the internet, which will cost you if you wifi isn't connected since it defaults to the cellular providers internet. It cost be about $12 for less than half a MB of usage. Their rate per MB is more than $50, im not kidding.. just checked my bill. If you just got the phone you can get the charges reversed just say you didn't know it would connect to the cellular web and that it cost so much etc etc. They should be lenient if you just got the phone etc...
Mar 07, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
About the battery duration of nokia 6233
Hi if you mean your battery isnt lasting long then you can buy a heavy duty battery for your phone from any phone shop but these can be expensive to buy.
The best way to prolong the life of your battery is to let it go totally flat once a month so flat that the phone wont even try switching on then do a full recharge doing this prolongs the life of the battery and will give your phones battery longer charge.
All phones are advised to do this as it keeps the battery in best condition and stops it from breaking down
Mar 30, 2008 | Nokia 6233 Cellular Phone
Won't come on
their is nothing you can do but replace the battery have you triedl etting the battery go totally flat so the phone dont even light up then try full charge again you are supposed to do this every couple of months this prolongs the life of the battery if this dont work then the battery will need replacing hope this is some help
Oct 21, 2007 | Siemens CL75
Sony Ericsson K320i Cellular Phone Logo
21 people viewed this question
Top Sony Ericsson Cell Phones Experts
Jose Cada
Jose Cada
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
