Question about Canon PIXMA MP190 All-In-One InkJet Printer
I can print txt. files but when I go through the solutions menu and or just pull up a picture (jpg ) from documents and hit print I get a message saying : this printer has known compatibility problems . says cancel or run , if I hit run it runs like it's printing but does nothing when the paper comes out it's blank . the printer has ink and it will print txt. files but not jpg. files . I checked it's compatible with windows 7 which I have . I downloaded a different driver but have the same problem . anyone know a solution for this ?
    Top Expert:
  • Canon Master
  • 12,962 Answers
Did you ask for support from the folks up at Canon? This appears t be a software issue.
Posted on May 08, 2017
  • 10 Answers
SOURCE: canon pixma mp190 driver for windows me
On January 18, 2007 Canon released new Windowme drivers for the following printers and multifunctions:
S100, S100SP, S200, S200SP, i320, i250, i255, i350, i355, S300, S330, i70, i450, i470D, i455, i475D, i80, S500, S520, S530D, i550, i560, S600, S6300, S630, S750, i850,  i6100, i6500, i860, i865, BJC-8200, S800, S900, S9000,  S820, S820D, i950, S830D, i9100, i990, i960, i965, i900D, i905D, i9900, i9950, MP360 Series, MP370 Series, MP390 Series, MP700, MP730, iP1000, iP1500, iP2000, iP3000, iP4000, iP4000R, MP750, MP760, MP780, iP5000, iP6000D, iP8500, DS700, iP90, DS810, iP1200, iP1600,  iP2200, iP6210D, iP6220D, MP150, MP170, MP450, MP500,  MP830, iP4200, iP5200, iP5200R, iP6600D
I have MP780 (print, scan, copy, and fax).  The released file mp780vst620en.exe does not install the multifunction MP780 correctly.
Does anyone know work around, please?
Posted on Feb 15, 2009
SOURCE: cannot print documents
replace ink catridge. wash with alcohol just only the head print. then place it. turn on printer without conect with ur pc. pres botton reset hold 3-5 minutes. then conect to pc. enjoy it
Posted on Apr 17, 2009
  • 184 Answers
SOURCE: Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
Select the name of the printer model to remove and select 'Uninstall.'
When the MP Drivers Uninstaller window is displayed, click 'Perform.'
When the confirmation window is displayed, click 'Yes.'
When the Uninstallation Complete window is displayed, click 'Complete.'
5. Reinstall the Drivers
The MP drivers can be installed using Easy Install or Custom Install.
Easy Install automatically installs the software which is in the CD-ROM.
This method is recommended if you are a first-time user.
Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
Close any antivirus software that may be running prior to installing the drivers.
Turn off the printer and disconnect the cable connecting the computer and the printer.
Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
At the main installation window, click 'Easy Install' or 'Custom Install'.
When selecting Easy Install:
(A) Click 'Easy Install'.
(B) Click 'Install' in the following window.
* Display varies according to the printer model.
When selecting Custom Install:
(A) Click 'Custom Install'.
(B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
When the License Agreement window is displayed, read the content carefully and click 'Yes'.
The installation will start.
Messages may be displayed during the installation of the application software.
Follow the instructions on the window and continue the installation.
When the Printer Connection window appears, connect the printer to the computer and power on the printer.
Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
3) Restart the computer.
4) Install the printer driver again.
For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
At the Print Head Alignment window, click 'Execute'.
* The Execute button may not appear for all models. In that case, skip to step 13.
* The Print Head Alignment can also be done after the installation of the printer driver.
When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
At the Do not start another operation until current one has finished dialog box, click 'OK'.
When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
At the Installation Results dialog box, check the content then click 'Next'.
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
At the Installation completed successfully dialog box, click 'Exit'.
Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Posted on May 22, 2009
  • 152 Answers
SOURCE: Canon PIXMA1500 prints blank pages
you need to change the print head ...
Posted on Jul 15, 2009
Sak-en na
SOURCE: How do you reset ink levels on a Canon pixma mp190 printer?
you can reset low ink error by pressing stop/reset button for 10 seconds
Posted on Oct 27, 2009
How do i change font size on cannon pixma mp190 printer
printer preferences, but that set-up is sent on the doc before being sent to printer. do you want to enlarge the print size, check under print preview
Feb 11, 2015 | Canon PIXMA MP190 All-In-One InkJet...
How can we install the Canon Mp190 printer? We cannot find the CD ROM. Is there any other way to install it in our laptop?
Good Day Dany!
To install the Canon PIXMA MP190 Photo All In One Printer driver, download the version of the driver that corresponds to your operating system by clicking on the appropriate link below. A window should then show up asking you where you would like to save the file. Save the driver file somewhere on your computer where you will be easily able to find it, such as your desktop. Then follow the instructions below corresponding to the file type that you downloaded.
Go to the location where you saved the file and double click on the file. Then simply follow the on-screen instructions for installing the driver.
1. Canon PIXMA MP190 Windows 2000 Printer Driver Download
2. Canon PIXMA MP190 Windows XP Printer Driver Download
3. Canon PIXMA MP190 Windows Vista Printer Driver Download
4. Canon PIXMA MP190 Windows 7 Printer Driver Download
5. Canon PIXMA MP190 Windows XP 64-bit Printer Driver Download
6. Canon PIXMA MP190 Windows Vista 64-bit Printer Driver Download
7. Canon PIXMA MP190 Windows 7 64-bit Printer Driver Download
Jul 24, 2011 | Office Equipment & Supplies
My Canon MP190 printer prints good, but at the left of the print the alignment is too much to the left, so capitals "fall off" the page. Canon says it is not a printer problem, but something else, but...
Click Start
Click All Programs
Click Accessories
Open Notepad
Click File
Click Page Setup
Check that the "page-margins" are not set to '0.0'.
Or, start Microsoft Word or Works or whatever "text-editor" that you use, and similarly check the "printer setup" for "left-margin".
Sep 20, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon mp190 pulls paper in right side only
Canon support has info regarding this problem for your model. You must be willing to type in the question:
"Paper feeds skewed" and click <Search> button.
Review the top solutions. I recommend that you clean your feed rollers.
Canon MP190 Feeds Skewed
Dec 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Check the settings of your printer's print quality it might be set to EconoMode.
Nov 18, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper pulls to right side and bunches up
Have you tried pulling off the back cover and wipe the rubber wheels off. some times they get dust on them and can cause them to not be able to grab the paper correctly.
Oct 22, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Oct 19, 2009 | Canon PIXMA MP190 All-In-One InkJet...
We have a new Canon MP190 printer. Cannot figure
1. Go to the following link:
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP190"
5. Click "GO"
6. Under "Please enter your question:", enter the following text: "How do I install the ink cartridge(s)?"
7. Click "Search"
8. From the search results, select the first selection. You will get a page with diagrams illustrating how to install the ink cartridges.
May 15, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Printer canon pixma mp190 installed need to chage to english
Since you have your printer pre-installed in Arabic, your best option is to get the english version of your printer driver and re-install it.
when you get to the link i will leave you with. download the file with this name:
Apr 26, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Canon PIXMA MP190 All-In-One InkJet Printer Logo
old marine
old marine
