Question about Logitech V220 Mouse
E9080 Wireless Touchpad Keyboard - Logitech V220 Mouse
I can't click on anything on my home screen. Gateway N522 series. Won't tab or do anything. Helpppp!!!
Try ensuring that the touchpad hasn't been accidentally disabled (Hold down the '[fn]' key and press the F6 key on your keyboard to toggle the touchpad(mouse) to be enabled or disabled.
Have you tried using an external keyboard and mouse?
If the external keyboard and mouse work then we know it is something to do with the built in keyboard and touchpad on your laptop (likely - but not positively a hardware issue). If it does not work then we know that the issue is likely (but again not positively) software based.
Jan 20, 2015 | O4Jelectronicswarehousecom Wireless N...
Repair the wireless connection
According to Rapoo, the solution is:
Rapoo 2900 E2700 E9080 pairing steps
1. Please first charge the keyboard to make sure the energy level is good.
2. the pairing steps are:
a : turn off the keyboard,
b: plug in the receiver,
c: turn on the keyboard
d :keep pressing "Esc" and "Pause break" keys for 5 seconds
3. If it is repaired successfully the mouse cursor can work normally. Please remember to plug the receiver again after successful pairing.
Unfortunately, I don't seem to make mine work at all :(
Maybe it's broken.
Dec 13, 2013 | Rapoo E2700 Wireless Multi-media Touchpad...
Acer Laptop Help
To get started with this product, complete the following steps.
Turn the laptop on by pressing the Power button located above the keyboard.
Locate the touchpad.
You use the touchpad much like you would use a mouse.
The touchpad controls your cursor.
It responds as you move your finger across its surface.
Move your finger across the touchpad to move the cursor.
Locate the bar below the touchpad.
This bar may be used for selecting and has left and right-click functions that you can use a mouse.
Clicking on the right end of the bar has the same effect as right-clicking with a mouse.
Clicking on the left end of the bar has the same effect as left-clicking with a mouse.
Tapping the touchpad is the same as clicking the left end of the bar.
Use the keyboard like you would use a desktop keyboard.
The only difference is that the keyboard of an Acer laptop is smaller than a regular laptop keyboard.
Click on the Windows icon in the lower left side of the screen to access programs.
Make sure your wireless switch is turned on, if you want to access the Internet.
Then locate a wireless network.
Windows may automatically detect and display a list of available networks.
If that happens, you only have to select the network you wish to access.
If it is not your network, you may need a password if it is security-enabled.
If Windows does not automatically detect a network, open Internet Explorer, and follow the on-screen instructions to connect to a wireless network.
Acer user guides and manuals
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ACER
May 24, 2013 | Acer Aspire Computers & Internet
My mother just gave me a toshiba laptop and she had a wireless mouse for it before. I do not have the mouse on it now and the mouse pad is not working. How do I restore it to the original setting?
Hi parothead91...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 05, 2011 | Toshiba Computers & Internet
Touchpad on Toshiba WIreless Keyboard PA3705D does not work. Help
I have the Toshiba PA3705D-1ET1 keyboard.
I experienced the same thing: keyboard working, but not the touchpad. I reinstalled all drivers that I could think off, but nothing helped. What actually did work for me was: remove the batteries of the keyboard for 10 seconds, then put them back in (while PC is turned on). Also ensure that the batteries are full and that you are in range of your PC (let's say less than 4 meters).
Jan 10, 2010 | Computers & Internet
Explain wireless keyboard wireless mouse
You just plug the usb adapter for the wireless keyboard and mouse into the computer and run the install disk. Wireless just means that the device sends signals to the recieving devices.
Jun 16, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Logitech V220 Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
