Don't Send error while running a vc++ Application
I wrote one Application in VC++ ,while running that i got dont send error, When i click on debug it is showing one message box like this "The instruction at 0x73debc9b referenced memory at 0x00000004"
how to understand this code.
please help me any one.
thanks in advance.
  • 428 Answers
If u use arrays and/or stacks make sure u access and write properly
Posted on Jun 24, 2009
Why customer can't add new VC-4 in VCTRUNK on EGS4 board, during board configuration limitation?
We check all customers configuration steps, and find that in VCTRUNK#3 in which they add new VC-4 #7 on EGS4 already have several VC-4s #11,13,15,16.
From product manual we know that "VC-4/VC-3 binding: VC-4s are divided into two areas, namely,VC-4-1 to VC-4-8 and VC-4-9 to VC-4-16. the VC-4s/VC-3s in these two areas cannot be bound at one time."
So we ask customer use VC-4s from different areas then they add it in VCTRUNK.
Nov 14, 2017 | Computers & Internet
Tip
Purchase of VC 125 sticker
Plz send me the graphic picture of 1996 VC 125 Dealim Sticker
Thanking You,
K.V.Kapila Lakmal Dharmapriya
No. 29/7,
Angammana Road,
Rathnapura.
Sri Lanka
on Dec 12, 2008 | 1996 Daelim VC 125
Hi this is amber I have 2x4 ohm qvc audiobahn abass2012P how would I correctly run them to get best bass n max power efficiency I have a soundstream Picasso 1000watt 4 channel bridge able amp to hook em up...
I assume you are replacing the built-in Audiobahn power amplifier with your 4 channel Soundstream amp. If so, you can set the Soundstream for bridge mode which should net you 2 high power channels of 250Wrms@4ohms or 500Wrms total power (if the speakers are quad VC), or alternatively, non bridged for 4x125Wrms (if the speakers are dual VC). You can see why below.
Next, you need to confirm each subwoofers coil configuration as follows: If each woofer is quad, there will be 8 connectors; if dual VC, then there will be 4 connectors. For dual VC, if each VC is 4ohm, you can choose between 8 or 2 ohms by series or parallel wiring. If each VC is 2 ohm, you can have 4 ohms in series to use. This can be determined with an ohm meter across one set of VC terminals. If you can get 4 ohm for each speaker, this will allow you to use the 2 channel bridged mode with each speaker getting the full 250W. If each VC is 2 ohm, use non bridged mode and run each of the 4 channels to each VC. For this case, use a 2 to 1 RCA jack to sum the two channels for each speaker on the amp's input side to make the signal 2 channel instead of 4 channel. Below are examples of quad and dual VC for reference only, the wiring may not match your setup which will depend on your VC resistance (impedance) measurement. Don't forget to set your HPF(High Pass Filter) as this is a subwoofer setup.
Nov 17, 2017 | Car Audio & Video
Http://www.facebook.com/people/Patricia-Geiss/100002655619425
+4917677424185 Email Transcript [HVD] ====== Start time: 1/5/2012, 2:12:7 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:12:7 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:12:7 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [YP] ====== Start time: 1/5/2012, 2:12:7 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, http://www.facebook.com/people/Patricia-Geiss/100002655619425 [YP] ====== Start time: 1/5/2012, 2:12:7 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [HVD] ====== Start time: 1/5/2012, 2:12:9 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, info@web.de [YP] GetYoutubeURLType() = -1, info@web.de [YP] ====== Start time: 1/5/2012, 2:12:12 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, info@web.de [YP] WinHttpCrackUrl() = 12006, info@web.de [YP] GetYoutubeURLType() = -1, info@web.de [YP] GetYoutubeURLType() = -1, info@web.de [YP] ====== Start time: 1/5/2012, 2:12:51 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, info@web.de [YP] WinHttpCrackUrl() = 12006, info@web.de [HVD] ====== Start time: 1/5/2012, 2:14:48 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:14:48 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [VC] ====== Start time: 1/5/2012, 2:14:48 [VC] Module VC Log Version = 1,7,15,426 [VC] OS Info 6 0 S 2 0 [YP] ====== Start time: 1/5/2012, 2:14:48 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, http://www.facebook.com/people/Patricia-Geiss/100002655619425 [YP] ====== Start time: 1/5/2012, 2:14:48 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [HVD] ====== Start time: 1/5/2012, 2:14:49 [HVD] Module HVD Log Version = 2,12,32,426 [HVD] OS Info 6 0 S 2 0 [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] ====== Start time: 1/5/2012, 2:14:51 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] WinHttpCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] ====== Start time: 1/5/2012, 2:15:11 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] WinHttpCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] GetYoutubeURLType() = -1, snc4/203372_100002655619425_1800818_n.jpg [YP] ====== Start time: 1/5/2012, 2:15:15 [YP] Module YP Log Version = 2,12,32,426 [YP] OS Info 6 0 S 2 0 [YP] InternetCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg [YP] WinHttpCrackUrl() = 12006, snc4/203372_100002655619425_1800818_n.jpg
Add Your Solution Or Ask For Clarification
Feb 09, 2012 | Health & Beauty
Look to find remote and power supply for vc-c4
The VC-C4 uses a Canon WL-V5 remote control, available at B&H Photo here. They also have a power supply for the VC-C50 here. The VC-C50 is almost identical in specification to the VC-C4, it's just a newer model. The electrical power requirements are the same.
Nov 11, 2009 | Canon VC-C4 Network Camera
Bridge mode
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password, doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
Jan 31, 2009 | Westell Wirespeed VersaLink...
Canon VC-C4 vs Logitech webcam
DO you realize that this camera cost around 900 US$? - Might be a little overkill for VOIP.
Apart form that it is an excellent camera. Have look at the manual here.
The camera connects via RS232 (9DSub) or 8pin DSub and you can/have to download the software form Canon's web page.
Jan 27, 2009 | Canon VC-C4 Network Camera
Chicony pc camera vc-350 driver
Hi *s*
go to
http://www.camera-drivers.com/drivers/88/88023.htm
this is free to download but you have to join up.
if that link is too old. go to
and search for 'chicony vc-350 + camera"
Poster states " Works great with windows xp."
This is free to download to your hard drive ok ?
The file is called P35.zip
the actual name is Divio NW801 PCAM Application
Thank you and good luck. *s*
Oct 26, 2008 | Chicony TwinkleCam DC2110 Webcam
Open Questions:
How to Remove a Virus from Windows PC or Laptop - Toshiba Dataalign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 22, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
153 people viewed this question
Alun Cox
David Payne
David Payne
