Question about Tricity Bendix Dryers
Not collecting water, I remove and all water pours out
6kg load
4 Suggested Answers
  • 24 Answers
SOURCE: Water collecting in the bottom tray and, at time, pouring out
The condensate drain is probably plugged w/dirt. You have to blow out the drain w/ some pressure to clear the drain.
Posted on Apr 15, 2009
  • 240 Answers
SOURCE: Water Pools Up in the Fabric Softener Area
have you dis assembled the dispenser drawer and cleaned out the sections. the top covers slide off their areas standpipe.
Posted on May 02, 2009
  • 30 Answers
SOURCE: water collects in the fabric softner dispenser
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Posted on Sep 03, 2009
Kenmore washer front load 3.5 super capacity clogged pump.
Remove the lower front panel and unscrew the LARGE 3" round plastic access cover. Have a drain pan handy as it will pour out water! Dump the coins, lint and whatever is collected in there, reinstall, tighten securely and replace the lower panel.
Jan 17, 2015 | Kenmore Washing Machines
Ed25rf
Water collecting in the bottom of the freezer is usually caused form a condensate drain blockage. Remove the back panel and there should be no ice around the drain. if there is pour hot water in and around the drain to clear it and flush it out. This should get things fixed.
Jul 23, 2014 | Whirlpool Refrigerators
My whirlpool duet washer is pouring water out the front- the seal seems perhaps loose and has collected dirt
There may be a hole in the seal which is allowing water to flow out. Remove front access panel or rear access panel and start new load and see where water is coming from. It may also be the coin trap hose, the pump, drain hose, Bellow hose. Check to see where water is leaking from.
If you need further assistance please comment me back
Jul 30, 2011 | Whirlpool Washing Machines
Wirlpool AWD60A 6KG dryer and it doesnt dry clothes
clogged dryer venting run 1 load w/the venting removed to confirm
Apr 13, 2010 | Dryers
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
May 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Apr 15, 2009 | Heating & Cooling
How do I find and clear the filter in Hotpoint Aquarius wf210?
pull machine forward andtilt back look underneath machine at bottom ofplastic tub u will c a black pipe leading from the tub t the pump unscrew from the tub end (put a bowl down first as water will come out)pull off pipe inside u will c a white platic collecter pull that out clean and put back together hope this helps
Dec 21, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
6kg Load Button
For a full load within 6kgs you dont do anything, just let it go thru the cycles. But when your load is half - you press the half load button. Good luck.
Mar 13, 2007 | Hoover AI130 Front Load Washer
Dryers Logo
14 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
