Question about Vigo Thermostatic Shower Panel with Rain Shower Head
Where can I get a replacement thermostatic cartridge for a VIGO VG-08008 panel?
    New Friend:
This is a very rare thermostatic cartridge. VIGO is a small brand and the above panel is no longer produced however I believe this cartridge from Di Vapor will work http://www.divapor.com/spares/showers/thermostatic-cartridge/thermostatic-cartridge-for-shower-steam-shower-tmv-temperature-brass-valve-push-fit-3-o-ring.php
Posted on Jul 22, 2015
Vigo waterfall bathroom faucet is just trickeling hot water when turned on, what should I look for?
problem in the tap washer (expanded and blocking the water flow
blockage inn the connection where the shower head connects at the wall
hot water flow restrictor so that you will not get burnt by the hot water --test by turning on the cold water first and then opening the hot tap as well
Jan 19, 2016 | Vigo Single Lever Waterfall Faucet with...
How do I get my samsung VG-KBD2000 to work on mt Samsung UE37 D6500?
the LED does not support a keyboard unless connected through a computer, for which the LED will have to be used as an external monitor and should have DVI ports to connect video cable.
Jul 24, 2015 | Samsung VG-KBD2000/BE Vg-KBd2000/xc/wls...
Vigo to lines across screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Mar 02, 2015 | Televison & Video
Oce tds 750 error code 08008
Hello, i got TDS 750 from Oc? and the error code is 08010.
Thinks for your help.
Oct 23, 2013 | Office Equipment & Supplies
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
Trim is coming off my 2000 Mercury Marquis. How do I use 3M's super weathership 08008 to repair it?
clean any old glue off both surfaces make sure it clean and dry put adhesive on molding then reaply to vechicle
Feb 14, 2011 | Mercury Marquis Cars & Trucks
95 acura legend doesn't overheat on freeway, but does on surface streets. I had the radiotor flushed and changed the thermostat.
Check your cooling fan or the temperature relay.  The reason it doesn't overheat on the freeway is because there is sufficient airflow to cool the motor down without the need for the fan.
Mar 03, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Vigo Thermostatic Shower Panel with Rain Shower Head Logo
421 people viewed this question
Top Vigo Home Experts
john h
Tom Chichester
Are you a Vigo Home Expert? Answer questions, earn points and help others
