Question about Haier Refrigerator Ice Maker Part H12mk
Ice maker will not dump ice - Haier Refrigerator Ice Maker Part H12mk
Ice maker does not dump makes ice but it will not dump need for someoneto tell me how to fix
check the gears on the motor doubt the teeth are stripped best fix is order a NEW ice maker complete.
Jul 17, 2015 | Samsung RB195ACPN 18 Cu. Ft. Bottom...
Ice will dump and refill when hitting reset button, but wont dump an fill on its on
Hello Jamie;
My name is Peter. I am a retired field service refrigeration technician.
It sounds like your have a bad ice maker sensor. On the ice maker mold is a long white coated wire. This is a temperature sensor. The sensor tells the ice maker control module that the water in the mold is frozen and to harvest the ice cubes.
The flex mold ice maker that you have is not repairable.
DA97-08241C Cost $135.00
Dec 11, 2014 | Samsung RS261MDBP 26 cu. ft. side by side...
Icemaker stopped working suddenly. Water supply is working fine.Ice freezes but will not dump into bin.
Good day,
If the ice maker is the style with a wire to turn it off and on, and is in the down position, then the ice maker is bad, as long as the temperature in the freezer is 12 degrees or colder.
(The ice maker locks out at about 14 degrees or warmer.).
You can replace the module, and thermostat in the the ice maker, but could be as well the mold heater.
The price of repair is so close to a complete ice maker, that it doesn't pay to repair.
You might want to get the complete model number. Check with any decent size appliance parts house, they should have what you want, if going to Sears is an issue.
Feb 04, 2010 | Kenmore Freezers
I have a refridgerator model 106.56664500 and it has stopped making ice. Can u help..
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 12, 2009 | Freezers
Ice maker is not working. Our freezer fridge side by side is about 8 yrs old...and now the ice maker is not making ice cubes. It is as if no water is getting to the machine. I have turned the...
Aug 29, 2009 | Freezers
The ice maker has stopped working
Aug 24, 2009 | Freezers
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Kenmore Coldspot side by side. The ice maker will
Hello. You will need to replace the icemaker. The swicth in the head is causing the arm to stay up and is not repairable. If you can get me the model number I can get you the part number.
Jul 15, 2009 | Freezers
Ice maker ice smells
Dump out the ice, let the icemaker refill the ice container, dump all that out as well and then it should be cleaned of whatever was in the line..
You may want to roll the fridge out and visually check the supply lines on the back of the fridge for contamination as well.
Jul 02, 2009 | Freezers
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Haier Refrigerator Ice Maker Part H12mk Logo
66 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
