Question about Westinghouse Refrigerators
Westinghouse fridge rs643 i have replaced the light globe it still doesn't work ,is there a fuse somewhere that i can change
SOURCE: Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Posted on Dec 12, 2007
SOURCE: I need to replace light globe in westinghouse
I rang Westinghouse and they gave me the type of globe I needed.
Many Thanks
Posted on Aug 05, 2009
heatman101
  • 43501 Answers
SOURCE: I have a westinghouse rs643 that is freezing in
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Mar 11, 2011
  • 5370 Answers
SOURCE: Westinghouse frig. Model RJ522G-1 Need to
CHANGING THE LIGHT bULb Refrigerator Light:--- 1 . Switch off the power at the power point and remove the cord by pulling the plug . 2 . Carefully unclip the light cover by pulling the light cover tab at the rear, towards you . 3 . Unscrew the light bulb and replace it with a new bulb of the same type and wattage . If, when you remove the light bulb the small rubber "O" ring comes out with the bulb, fit the "O" ring over the new bulb and screw bulb into the socket.--------- warning:-- Never insert your finger into the light bulb socket to check for the presence of the "O" ring. 4.Replace the light cover by hooking the lugs into the front of the housing and pressing the rear of the cover up until it clips in . 5 . Wait 5 minutes to ensure pressures in the refrigeration system are equalized, before turning the refrigerator on at the power point .-------------------- Freezer light At the top section:-- 1.Switch off the power at the power point and remove the cord by pulling the plug . 2.Carefully unclip the light cover by pulling the light cover tab at the rear, towards you . 3.Unscrew the light bulb and replace it with a new one of the same type and wattage . If, when you remove the light bulb the small rubber "O" ring comes out with the bulb, fit the "O" ring over the new bulb and screw bulb into the socket. And insert in reverse.-------------- this will help.thanks.Helpmech.
Posted on Jun 13, 2011
  • 823 Answers
the manual doesn't say anything about changing the globe. Here is a link that explains how to change it and also how to troubleshoot other Westinghouse Refrigerator problems:
http://www.ehow.com/info_8224051_white-westinghouse-refrigerator-repair.html
If you want a product brochure or basic manual you can get one from the manufacturers website. Here is a link to that website:
http://www.westinghouse.co.nz/content/brand/brochure
Cook top lights don't work. Replacing bulbs didn't help. Is there a fuse somewhere four just the lights? Everything else works.
You can check check if the power is available in yo bulb holder , if its not you must change the bulb holder and also if its there you must get another globe
Sep 13, 2014 | Microwave Ovens
Replacing a fuse on a circuit board of a westinghouse rs643 refrigerator
as far as i know , there is no fuse on any board in rs643 models !!
Apr 18, 2014 | Westinghouse Refrigerators
The light is not working on my Westinghouse rs643 refrigerator,I have replaced the globe
Check the switch inside the door frame is being contacted when the door is closed, and opens when the door is open
Where is the circuit board located in a westinghouse rs643 refrigerator
I don't believe the light has a separate fuse. Isn't there a switch that operates the light when the door is open? Check the contacts make when door opens
Westinghouse ETL-ES-TurboSwirl-MN-WH09 ceiling fan glass globe part#
There is a chance is says on another light bulb,a little tag with a number.
Mar 09, 2014 | Hunter 23852 Classic Original Ceiling Fan
Westinghouse range hood wrf900cs light blew, light globes replaced but lights still not working
I had the same problem. An audible pop and the lights stopped. Fans still works, light bulb filaments appear intact.
My problem was that a short piece of the copper on the printed circuit board, inside the switch housing, had vaporized as if it were a fuse. I soldered a bridge of copper wire across the small 5mm gap and all was working again.
Access the switch compartment by removing the filters, undo a couple of retaining screws to remove switch unit.
Make sure the electricity to the unit is Off/unplugged before proceeding!!!
Switch unit cover has 4 screws holding it on. Once inside the unit, trace the wire (mine was grey colour) from the light switch to the small printed circuit board. The copper printed circuit link to the connector had gone...no sign of burning, just gooone!
Solder a bridge of copper wire across the gap and reassemble switch unit to test.
....send beer donations to me in qld...cheers!!!
Jun 29, 2012 | Kitchen Ranges
I have a westinghouse rs643 that is freezing in the fridge evan on the lowest setting ,could it be the thermostat.
heatman101
Mar 10, 2011 | Westinghouse Refrigerators
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Nov 03, 2009 | Westinghouse Refrigerators
Need new globes on lights
Go to lowes or home depot as both places carry replacement globes in stock. They can also special order for you. Bring in one of the old globes to be sure you get a perfect fit.
Apr 28, 2009 | Westinghouse Helix 78794 Chrome Finish...
Refrigerators Logo
26 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
