Bad ink level indicatior - Office Equipment & Supplies
My dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
Ink level is not real
FIRSTLY the only way a printer will no show inks Original Level is when the Inks are Refilled or Fake... Check if the inks are are Not fake... Can you tell more of the issue you are going through as to know what problem you are facing....Hope to hear from you soon.
Regards
Obehiadoghe@yahoo.com
Nov 15, 2013 | Office Equipment & Supplies
Samsung tv no led indicatior glow.. voltage regulator 3s125r have a primary voltage and secondary no voltage
if no secondary voltage at the regulator that was mean the regulator is bad which need replacement.the output supply will not pass through to the other circuit which turn on the tv.
Aug 17, 2012 | Symphonic ST420FF 20" TV
I want to check ink levels. It is blurring the color when printing
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Jun 21, 2011 | HP LaserJet CP1518 Printer
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
Oct 05, 2010 | Office Equipment & Supplies
Ink levels are good, but printing is not.
Your print head is bad... If its a newer unit call the manufacturer and they should send a replacement
Dec 07, 2009 | Dell 3100cn Laser Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
HP Deskjet D1460 (Ink level problem)
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Jun 16, 2009 | HP DeskJet D1460 InkJet Printer
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
Jul 30, 2008 | HP Office Equipment & Supplies
10 people viewed this question
k24674
