Question about Nespresso Le Cube
My pod is stuck lever won't release it - Nespresso Le Cube
In the Gitzo GH2750QR head the quick release plate got stuck. What to do?
Is it the plate itself that is stuck, or is it the lever that needs to be moved to release the plate ? From a brief look at images of the item, it looks as if there is a small locking lever connected to the actual release lever - has this been freed, or is it that which is stuck ?
Nov 13, 2016 | Gitzo Gh2750qr Series 2 Magnesium Off...
The lever on my nsepresso machine is stuck
ive had this before. cause was a pod that got jammed
where are you situated?
try to push cover (where you insert pod ) and lever at the same time. i gave mine a bit of force at the same time and it worked.
Jun 28, 2016 | Coffee Makers & Espresso Machines
Ford Expedition seat won t fold down
My ford had same problem. I resolved it as follows:
on the side of the seat that has the cable handle that isn't working remove the INSIDE plastic covering. This will just pull off. This is thee plastic piece underneath the seat. Once this is done you have access to the lever that the cable pulls against. My was frozen stuck. I took a long screwdriver and placed it against the top of the lever and struck the end with a hammer. This unseized the lever. At this point the seat could be pulled up but pulling on cable. I then sprayed wd40 on lever joint.
May 21, 2013 | Ford Expedition Cars & Trucks
Can not remove capsule and lever stuck
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Mar 10, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Girls skeleanimal bike brake is stuck so back wheel won't move
It's a Huffy. 'Nuff said.
Manuals here - http://www.huffy.com/Support/OwnersManuals.aspx
If the cable isn't passing freely inside the cable housing it won't relax brake pressure when the lever is released.
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Jun 19, 2011 | Schwinn 20 Inch Girls Starlet Bike
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
Dumb question, How do I release parking brake on 88 DeVille? Thought there would be a lever somewhere but I can't find one Also, I've been told it needs premium gas. Is this true?
You have a car that was built withh all the bells and whistles you know. The emergency parking brake is not so sophisticated at all. Cadillac installed a vacuum pod to the release actuating lever which conjoins to the shift bowl. When you aplly your foot on the brake to shift the emergency brakes will release automaticly. If it will not release, the vacuum pod is at fault & will need a replacement. They are inexpensive at any Cadillac dealerships parts department.
Jun 20, 2010 | 1988 Cadillac Sedan DeVille
Top will not unlock
It seems to be caused by pressure build up (not a vacuum) when the outlet of the pod holder gets blocked. There are three plastic bolts that slide into place to lock the lid as the lever is operated. Pressure forces the lid up and increases the friction on the bolts to the point where they won't operate. Solutions 1 and 2: First disconnect Senseo from the electric supply. Solution 1 is to press down on the lid to overcome the pressure and then operate the lever to unlock. Didn't work for me. Solution 2 is to get a table knife, not sharp, no serrations but with a rounded end, not pointed. Insert under lid just to right of pod holder handle, at an upwards angle of about 20 degrees to the horizontal. Then aim for the opposite 11 o'clock position on the closed lid. With a few tries the knife blade should slide between the top of the pod holder and the rubber sealing gasket releasing the pressure. Beware hot steam/water as pressure is released - wear gloves. Open lid, unblock pod holder hole with a pin, fill and heat resevoir and then flush through without a coffee pod in place.
May 21, 2010 | Philips Senseo HD-7810 Coffee Maker
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you...
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you help?
Feb 23, 2010 | Krups Coffee Makers & Espresso Machines
Stuck senseo maker
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Oct 28, 2007 | Philips Senseo HD-7810 Coffee Maker
Nespresso Le Cube Logo
59 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
