Question about Metra Car Audio & Video
How do i wire a toyota granvia starter motor - Metra Car Audio & Video
1996 Toyota granvia fuse panel is in Japanese translation into English
There's this website www.reliable-store.com
They have books on ALL vehicles.
it covers wiring diagrams,
electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
Mar 17, 2018 | Toyota Cars & Trucks
Location of fuse for radio
In the passenger compartment fuse box.
Apr 28, 2016 | Toyota Cars & Trucks
Fuse for radio toyota granvia
Should be either on the panel under the dash or under the hood, google your year, make and model and it will give you the exact location
Apr 28, 2016 | Toyota Cargo Cars & Trucks
HOw do I remove a starter motor from a Toyota HiAce
Replacing brushes on a starter motor is not a job for a novice. However, the procedure is simple. Remove a battery cable, best to remove the earth cable.
Now get yourself in under the vehicle and identify the starter. There should be at least two wires, usually more on the solenoid. One is the positive battery cable, one is the solenoid actuator wire which just pushes onto a spade connector. Any other wires are connected to the same terminal as the battery cable. Remove all these wires from the solenoid.
Either two or three bolts attach the starter to the engine block. Remove these bolts and voila, the starter is out.
Have fun.
Oct 19, 2014 | 1995 Toyota Hi-Ace
Steering rod / pinion - front L brake, 1996 Toyota Granvia 3L 4wd auto
Your e-mail was way out. Toyota Granvia is a motor vehicle. Problem has been resolved, No need to add my mystery to your list.
Apr 23, 2008 | Televison & Video
Car Audio & Video Logo
26 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
