Question about Panasonic KX-FLB756 Plain Paper Laser Fax
Error change drum intellifax 756 - Panasonic KX-FLB756 Plain Paper Laser Fax
Change drum error in panasonic kx-mb1900
Dear friend , you guided about Brother printers not for Panasonic . There is no any option key on the panel of Panasonic kxmb1900 .
Dec 14, 2012 | Brother IntelliFAX 3800 Plain Paper Laser...
Error code "change drum soon
This is NOT an error code...the machine is simply telling you that it has run/printed a certain number of pages and it will soon be time to replace the drum.
Oct 27, 2010 | Brother IntelliFAX 2800 Laser Fax
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 2800. Replaced drum, display
Open the drum cover and hold down CLEAR for 10 seconds.
Jan 28, 2010 | Office Equipment & Supplies
Intellifax 4750e, prompted us to change the drum soon. We did change the drum but it is still telling us to change drum soon.
We went to Brother website and obtained a manual and we were forgetting to reset the counter. Once the counter was reset, the message went away.
Jan 13, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Change drum sign
open the front door, you will see the toner cart and the drum pull out the drum unit to you, good luck
Dec 22, 2008 | Brother IntelliFax-2820 Laser Fax
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 4750e
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Mar 27, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother intellifax 4100
open front cover, press "clear" and 1, that will clear the change drum soon error
Jan 14, 2008 | Brother IntelliFax-2820 Laser Fax
Panasonic KX-FLB756 Plain Paper Laser Fax Logo
22 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
