Question about Whirlpool Ovens
How to change a diode in whirlpool MH1150XMQ0 microwave
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
Mmv5207bas will not heat
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise.
Here is the part to order.
Jun 22, 2013 | Ovens
Microwave is not make food hot
Hi.
The wave emitting part inside the microwave oven is called the magnetron. The waves emitted by the magnetron generate heat in food. When the microwave is running, turntable turns and light comes on but there is no heat it means that either the magnetron is faulty or the magnetron is not getting power. When the magnetron is not getting power parts such as the high voltage diode or capacitor must be tested or replaced. Testing and repair must be carried by a technician. Here some general troubleshooting: http://www.fixya.com/support/r2096491-microwave_works_normally_but_not_heat
Regards.
Ginko
Sep 05, 2011 | Whirlpool Ovens
Mirowave do heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 09, 2011 | Samsung Ovens
My microwave over works but no heat
Sorry to read about your problem, I hope this helps you out.
you could have one of the following issues
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE Ovens
Can your provide me the Instruction manual in English language for Whirlpool Microwave Over Model No.MT 228/WH.
Please try these links and post your query.
www.devicemanuals.com/guide/???Microwave%20Oven/???Whirlpool-manuals.html
www.retrevo.com/samples/???Whirlpool-Microwave-manuals.html
Sep 27, 2010 | Ovens
Microwave doesn't heat everything else working fine...just replace capacitor and diode and still not working what else is wrong? Please help. thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | GE JTP86 Electric Double Oven
GE jkp85 Microwave oven appears to be working
Most likely related to magnetron and diode this is for qualified tech to do only.
Nov 13, 2009 | GE JKP86 Electric Double Oven
Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 26, 2007 | GE JTP85 Electric Double Oven
Ovens Logo
12 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
