Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
My hotpoint aquarius WD440 has drying flashing light
3 Suggested Answers
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
SOURCE: hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Posted on Sep 01, 2012
Hi i have a hotpoint aquarius wd440 14000 spin i have flashing lights on the on off and on the drying heat. It is a washer dryer .but I never use the dryer. can somebody please tell me what's
I believe your issue is a blocked/clogged water drain. If your unit appears to drain all of the water at the end of the cycle, you may just need to clean your filter. The machine can sense when it takes too long to drain and it flashes those particular lights to let you know what the problem is.
Dec 22, 2014 | Hotpoint Washing Machines
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440. Flashing lights
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
13 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
