Question about Westinghouse Refrigerators
Replacing a fuse on a circuit board of a westinghouse rs643 refrigerator
  • 30 Answers
As far as i know , there is no fuse on any board in rs643 models !!
Posted on Oct 31, 2014
Samspade30
  • 15 Answers
SOURCE: I need a 120v power supply circuit board
Ok here is the poop. I just tore mine apart the green light did not come on and the fan did not work. I looked at the circuit board I don’t know how many times before and missed a covered fuse. There is one (maybe it is a decoy) fuse that sits out in the open it was fine. But this fuse is next to the outlet wire on the circuit board was blown. It is small and covered with black shrink tape. This fuse is very easy to overlook. I unsoldered the ends and replaced the 12V 5 amp fuse. I used an inline fuse holder during replacement so if it goes out again I can just change the fuse. It is worth a look, good luck.
Posted on Aug 07, 2009
localwonder
  • 6784 Answers
SOURCE: My LG refrigerator has a blown fuse on the circuit
Yes. This fuse is replaceable, but, you will heed to De-solder the contacts, in order to remove the damaged fuse. this can be very challenging. If you are not an avid user of a soldering iron, i would just simply replace the board. If the soldering is not done correctly, this will cause the board to short, causing a spark.
I would , also, verify that the fuse is available for a non technician to purchase. Most vital components will not be available for purchase, if the purchaser is not a certified tech.
Posted on Oct 21, 2009
Testimonial: "Very helpful"
  • 22 Answers
SOURCE: The circuit board has a 25 Amp slow blow fuse is blown
if your circuit board has a 25 amp fuse that a lot of power, like running the compressor.. you need to have a model and serial number for the unit , there is no generic control board , each manufacture has it's own design
Posted on Nov 15, 2009
  • 2418 Answers
SOURCE: The fuse on my circuit board for my kenmore
Yes you can solder a new one in place just have to be careful, you can also, if you have room, solder in a new holder in case it blows again it will be easy to repl.
Posted on Feb 27, 2010
heatman101
  • 43501 Answers
SOURCE: Refrigerator is 2years old. The refrigerator is not working but
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
I have a Westinghouse LCD TV, model #CW40T6DW. The TV turns on shows the Westinghouse symbol, channel number and then turns off.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 21, 2016 | Westinghouse Televison & Video
On a LG LSC26905TT need circuit board location to replace fuse
How do you know the fuse has blown if you haven't accessed the board? Check the mains incoming power first, and power to the compressor. The pcb is usually in the top above the door frame.
Apr 27, 2014 | LG LSC26905TT Side by Side Refrigerator
The light is not working on my Westinghouse rs643 refrigerator,I have replaced the globe
Check the switch inside the door frame is being contacted when the door is closed, and opens when the door is open
Apr 18, 2014 | Westinghouse Refrigerators
Where is the circuit board located in a westinghouse rs643 refrigerator
I don't believe the light has a separate fuse. Isn't there a switch that operates the light when the door is open? Check the contacts make when door opens
I have a westinghouse rs643 that is freezing in the fridge evan on the lowest setting ,could it be the thermostat.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 10, 2011 | Westinghouse Refrigerators
Replacement parts lt32d-2
Replaced that capacitor,check all around for others bulges and puffs up capacitors,replaced those capacitors too.The power supply board should work than.Not than u must have electronics Tech.skills to trobouble shoots the board to replaced parts.Best,than just replaced a whole refurbish power supply board.
Apr 06, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Burned our fuse in circuit board
it is a 250V 15 amp. clip the fuse off the wire, close, and solider in a new one. Terrible design. LG should have to replace free or be sued !
Feb 23, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
purchase a AC to DC adaptor and use the 12volt power cord plugged into it.. these are commercially available, just make sure you purchase an adaptor that can handle the power used by the fridge which is on the back of the unit.
May 30, 2009 | Sharper Image (SI714SL2) Compact...
RM2652 WORKS ON GAS NOT ON AC ALL FUSES OK POWER
www;
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
77 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
