Question about Bosch HEI7282 Electric Kitchen Range
BOSCH HEI7282C OVEN WITH ERROR CODE 160
I owned a Bosch oven since 2009 without any problem. And now, when I start the oven the error code 160 appears. In convection mode it is ok.
5 Suggested Answers
SOURCE: error code
I have the same problem. Just had the control panel repalced Friday because the oven would "magically" turn it self on for no reason. 5am I'm in bed and I hear beeping. Go downstairs to see my broiler on... Anyway. Had the control panel replaced. Seemed to work fine. 2 days later, we try to use the oven and we get "error 160". I called Bosch and they couldn't tell me what that means. This will be my third service visit in 3 weeks. Glad the unit is still under warranty, but I'm not looking forward to October when it's up.
Posted on Jun 03, 2008
  • 479 Answers
SOURCE: We have just replaced the
for what problem did u replace the board
Posted on Oct 03, 2008
SOURCE: error 160
Error 160 is the error code that corresponds to the fact that a new controller board has been installed, but not yet programmed to your model of appliance. Companies now tend to use a standard board for multiple models, and upon installation it needs to be "programmed" to tell the board which model it is. This is a simple step, but usually involves pushing a couple of buttons at the same time, then selecting your model number from a pre-programmed set of options. The instructions should come with the new board, or the company can provide if you can get them on the phone.
Posted on Nov 03, 2008
SOURCE: Bosch convection oven in self clean mode, am
Hi, I am getting the same error today. Did it ever clear up? Were you able to open the door eventually?
Posted on Mar 19, 2010
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
Hbl8450 E118 error
E118 indicates a comma error. You could check for loose connector block or plug on ribbon cable. Best course of action is to call a Service Engineer.
Sep 19, 2017 | Bosch Ovens
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Open Questions:
Bosch HEI7282 Electric Kitchen Range Logo
429 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
